Trump GT6+ as a donor?
merkurman - 28/11/06 at 01:51 AM
ok so small chassis donors are tough to come by in the US but I have a line on a GT6+ at my landlords for cheap (wants it gone) the car has been sitting a LONG time. lots of rot on the car but would this be suitible for a donor for rack/uprights/IRS?
Humbug - 28/11/06 at 07:27 AM
This thread about Spitfires semed to be against the idea:
http://www.locostbuilders.co.uk/viewthread.php?tid=55579
britishtrident - 28/11/06 at 07:46 AM
Uprights and rack are as near ideal as you will find however check the condition of the threads at the bottom of the upright where it screws into the trunnion as these corrode/fret/wear badly if not kept lubricatd with (straight ie non-ep) gear oil.
Do a search on the forum --- the subject has been covered many many times.
hughjinjin - 28/11/06 at 11:54 AM
front end is one thing, if you're prepared to do a re think of the front suspension the it can be made to work very well. there are generations of single seater racing cars out there (formula ford etc) running on these uprights as well as numerous Lotus road cars. If you do decide to use them and are looking for spare parts remember that they are not identical to the more common herald/spitfire ones, the brakes are bigger and the caliper mounts are different.
the rear end however is not up to the job. If you use a modern 16v engine the diff will break, and the rubber donut type drive shaft joints are crap!
Arthur Dent - 28/11/06 at 04:09 PM
I think you'd be better off parting out on eBay (bits are worth a good amount - especially trim, brakes, etc) and maybe keeping the rack or spindles. Engine is very heavy and quite large, rear won't take too much power.
merkurman - 29/11/06 at 03:12 AM
well I figured I might keep the motor if it isn't seized (cheaper to work with what you have on hand) I could always repower it later on. so basicly redo my geometery and go for it or look for a different donor (assuming the uprights are still good?)
sorry I have been wanting a locost for about 3 years now and HAD a XR4Ti for a couple years I was thinking of breaking for a donor but ended up selling it. figured I would just keep an eye out for a good donor for now and collect little bits. I just picked up a 5 gal General motors fuel tank that is PERFECT for a locost. about the size of a "jerry" can with built in pump and sending unit and a fill cap mounted to the tank. about 18"h x 13"l x 8"w. nice poly unit with grooves for retention straps on it. it is an EFI tank and has a 3/8" pipe coming off it for the vent (EASILY adapted to a tipover valve) from what I picked up on they are used on cab/chassis trucks so they can be moved around (8.1L engines) until a comerical body is fitted (like tow trucks, moving vans and such) and then they are tossed (tank is marked TEMP USE ONLY)
Arthur Dent - 11/12/06 at 10:27 PM
I'd just take a good long hard look at the size and weight of that motor. Might be best to sell it off to a Spitfire or GT6 guy.
macnab - 12/12/06 at 12:23 PM
Triumph engines suck. Even my brother in law who's a triumph fanatic agree's their poop!
Arthur Dent - 12/12/06 at 11:27 PM
fun with thrust washers!
martin1973 - 23/12/06 at 09:49 PM
i'm a bigg fan of triumphs myself, run a 68 vitesse as daliy driver, couple of heralds to,
the triumph 6 is on of the best engines of it age, sounds great through a ss exhaust.
looking down this avenue myself,
macnab - 31/12/06 at 12:54 AM
I agree about they sound nice and they pull well, but I spent 3 days trying to get my brother in laws one to run properly and still its not right.
[Edited on 31/12/06 by macnab]
martin1973 - 1/1/07 at 08:00 PM
whats it running carbs or lucas injection?
