I've got a "lightly" blown up SVT focus (ST170) engine lying about (bad cambelt failure -- 8 broken exhaust valves couple of dinged
pistons and a smashed exhaust valve seat) -- I've started eyeballing it as a starting point for a Tiger ERA inspired single seater (this engine
is probably beyond economic redemption but suitable for mocking up -- it's a decent engine in the focus but i imagine it would sparkle in a
1,000lb-ish car).
The Passat 1.8t gearbox has been mentioned in other threads, I'm not sure if it would look as pretty as the Hewland but it definitely fits the
budget better.
Bodywork looks simple enough, perhaps a glass nosecone/ring and a few sheets of aluminum formed and riveted, locost-like chassis and suspension arms.
Build in a bit more space for my, err, North American proportions
Perhaps some minimal lights and cycle fenders attached with quick disconnect pins:
to allow you to drive to the track.
Any thoughts? Should I just scour the ads for a thrashed formula ford instead?
Cheers, Ted
Sound like a good project to me
I agree with your comments about the engine
i've thought of doing something similar for the last few years - although i'd probably just use an Audi engine as well (prob v6 for looks).
I've always loved the ERA, but not at the price that Tiger want! As you say, it doesn't look too hard to sort out, as it's a tiny car. Although to drive it on the road, I would want some mirrors too! As said, a V6 would look even better. Maybe the smaller Mazda lumps could do it? IIRC they make a 1.8L V6 that would do the job nicely.
Wouldn't recommend the Formula Ford route - been there done that! It's a nightmare trying to get the ride height up to a sensible clearance, plus if you have "err, North American proportions" you would have to mod the chassis to get in it!
also are you looking to track day it? if so there might be a few issues with the single seater type thing, they dont normally like them do they,
unless they are road legal with mudguards on them? so if you were formula fording it youd also have to make the ford legal for the road
love your
build it idea tho, that is a nice car in the pic!
[Edited on 19/12/08 by hellbent345]
Originally posted by hellbent345
also are you looking to track day it? if so there might be a few issues with the single seater type thing, they dont normally like them do they, unless they are road legal with mudguards on them? so if you were formula fording it youd also have to make the ford legal for the roadlove your build it idea tho, that is a nice car in the pic!
hi,
looks like a cool project to me. does anybody know what uprights the tiger uses? or have some pictures of one being built?
blake
you might all so want to look at the LCC rocket for inspiration in a simaler direction
The Spire GTR runs just like that. The prop shaft is just 2 UJs bolted together! Although it might look a bit odd, as you wouldn't have the big hewland type box hanging off the back, but maybe it's look better.
Looks like I was lying. The prop is 293 long.
Have a look here for a lot of build pics and further info.
This is the prop he used.
[Edited on 21/12/08 by DIY Si]
293mm is a bit less than a foot, so pretty minimal, looks to have a slip joint in it still -- appears the side cover on the engine extends a bit so
the foot of prop shaft may be required.
I need to grab a motorbike engine and a diff and start mocking things up.
Cheers, Ted
keep posting to let us know how you get on as it looks like an interesting project to me
