As above really,
Spent some real time on the kit today.
Check out my blog if you like!
http://sdrv-stormbuilddiary.blogspot.com/
A few hours in the garage.
sometimes, is worth more than weeks of toll in the garage
steve
Its always good to get a good run at things to make progress. I get really frustrated with just the odd half hour here and there.
ETA: ive also Made some Good Progress Today
[Edited on 22-4-11 by MakeEverything]
Nice one - & sh*t me thats a tasty compressor
I've been in the garage all day, only just come in at 23.10
Originally posted by Andybarbet
Nice one - & sh*t me thats a tasty compressor![]()
Great looking build! I just wanted to suggest that you fit a proper mechanical switch for the brake lights that actuates from the brake pedal itself
rather than the hydraulic pressure switch you've used. I've never found them to be very reliable, and it's a lot easier to do these
things now while you've still got good access.
Just my opinion! I'm sure loads of people have used them without problems, but I've replaced two now on separate cars because they both
failed (they only switched when there was enough pressure to lock the front wheels!)
Ed.
2nd that, use a proper switch for brake lights - those take too much pressure to activate and can trap air fitted that way up.
Cracking build BTW
Originally posted by Madinventions
Great looking build! I just wanted to suggest that you fit a proper mechanical switch for the brake lights that actuates from the brake pedal itself rather than the hydraulic pressure switch you've used. I've never found them to be very reliable, and it's a lot easier to do these things now while you've still got good access.
Just my opinion! I'm sure loads of people have used them without problems, but I've replaced two now on separate cars because they both failed (they only switched when there was enough pressure to lock the front wheels!)
Ed.
