I am looking for a small scale manufacturer for resin domed labels to put on my new build wheels. I can supply the art work in .jpg format. These are
the centre caps that used to house a oval Ford label. Obviously I can refit the Ford labels off flea bay but I was hoping to be more imaginative. I
realise modern alloys no longer have centre caps and most of you would throw them away anyway but I want to retain my wheel centre caps but not with
Ford on them.
I have tried a few internet sites but I doubt they are interested in the tiny quantity I have in mind.
Check out ebay item number: 250970969280
It says:
Create Your Own Wheel Centres!
Do you have your own design? Want to stand out from the crowd?
Then we have the perfect product for you!
You may choose any size from 35mm to 120mm in diameter.
For more sizes, please get in touch.
^^^Choose your size from the drop down box above^^^
Simply send us the image that you want to appear on your wheel centres, and we will produce them into 4 stunning self-adhesive decals in your chosen
size.
We accept the following image files types only:
JPEG, TIFF, PSD, EPS, AI, PDF
All images should be at least 200dpi
Good luck
[Edited on 20/3/13 by Andybarbet]
I used these guys. They made me a nice set of Bongo centre cap badges!
http://www.heko.co.uk/
Cover your own stickers with polyester resin and leave it to harden off in the warm.
