Hi everyone!
I'm a Spanish young engineer attempting to design a "LeMans style" locost proto. (Like Radical or Funyo cars)
Now I am in the early stages of the suspension design and I am searching for the correct tyre to fit in the car. But I am a bit lost because I have
not much knowledge about commercial tyres specs. I have searched in the forum about this topic, but I haven't found anything. Sorry if this is
not the place to make ths question!
So,
I estimate the car will weight around 600-800 kg and it will have around 200 bhp. The car will race always on track and only with dry
conditions. And I am seraching for a tyre with good grip capabilities but specially with a long longevity (I am not rich enough to change a whole tyre
set each trackday!! haha).
I have several possibilities in my mind, but I am plenty of doubts.
Street/circuit Tyre (e.g. Toyo R888): They will have a good grip, but, How many km/miles will they last? Will they get on temperature with a
lightweight car?
100% Circuit tyres: Superb grip, low longevity, high price, designed for lightweight cars.
-Avon radial-slick: around 600km each set and 240€ (in Spain) per tyre.
-Hoosier R6: The same price as tha Avon... Longevity?
There are much more options, but all of them fall into one of this two groups.
Can someone with experiences with this tyres help me to make a decission? How long do the Toyo last? And the Hoosier? In terms of longevity/price,
Does it worth the difference between the Avon and the Toyo?
Sorry if my english is not the best of the world, if you don't understand anything, please tell me!!
Greetings
[Edited on 27/5/13 by osdecar]
You should also consider the race series that you propose to aim the car at as most will dictate what tyre you can use anyway.
The R888 has no problem getting up to temp opn a light car but you will have to run considerably lower pressure than you would typically expect when
using them on the road, also bear in mind that the R888 is available in different compounds, the medium compound is road legal but the softwer
compound isnt if i remember correctly.
also consider that you may want to also spec a rain tyre as R888's in the wet may not be your best choice. The MSa bluebook, the uk bible for
motorsport, lists tyres suitable for use and also seperates them into categories which most uk race series publish as their allowed tyres. see
here:
Linky
HTH
[Edited on 27/5/13 by snakebelly]
List 1B is the usual one used for your type of vehicle.
Erm.. Race tire compounds have a time limit AND a heat cycles limit.
Unlikely... either... will outlive a summer season's use.
The R888 has no problem getting up to temp opn a light car but you will have to run considerably lower pressure than you would typically expect when using them on the road, also bear in mind that the R888 is available in different compounds, the medium compound is road legal but the softwer compound isnt if i remember correctly.
also consider that you may want to also spec a rain tyre as R888's in the wet may not be your best choice. The MSa bluebook, the uk bible for motorsport, lists tyres suitable for use and also seperates them into categories which most uk race series publish as their allowed tyres. see here:
Linky
HTH
With a weight of 600kg my medium R888s have half their tread left after at least 5 Trackdays and about 5000 road miles. The light weight of the car was the biggest factor on this. Personally I've found the Yokohamaa A048 to be far more resistant to running at a hot temperature compared to R888s, so an A048 at a softer compound would be recommended from me. Medium compound R888 tyres need to get up to past 60degrees C to start working properly - nothing worse than buying tyres which never warm up enough. With medium compound you should be okay in the warm Spanish temperatures though - in the winter I can't get my r888s hot enough.
