Hi Fellas
I may have been a bit hasty about the integral m/cyls not fitting under the bonnet last 2 trial fits all ok
What clutch m/cyl bore are you Sigmas running 0.75 ? just asking as my engineer friend said the flow was important and Compbrakes do a 0.83 at sub £20
is it worth looking at ?
Starting to come together now i would put some pictures up if i wasnt such a biff with computors
Nick M
I fitted this on advice from Motorsport Tools "We would recommend the 0.625 for the front and 0.75 on the rear" I am not happy as braking effort is too high. Not sure what to change it to I think the front needs to be smaller.
Started ith 0.75 front and rear, soon changed it to 0.625 front and 0.75 rear and that gives a much better, softer feel to the pedal.
I suppose it's all about the type of 'feel' you prefer.
For the clutch I have 0.75 and that works perfect.
For brakes 0.625 both f&r and that gives a hard pedal feel, which I like.
Basicly I did I like Jeremy told me, he has built a few cars :-)
[Edited on 10/8/13 by monkeyarms]
Yep integral m/s do fit...
For me clutch-0.75
Rear brake-0.7
Front brake-0.625
Looks like 0.75 for the clutch then, i havent checked but i cant understand the flow thing as the pipe narrows so much at the g/box that it cant be
much more than 3/16 anyway ? when i questioned a mech he said 3/16 would probably do it then i mentioned my engineers name and "flow" he
then said go with what he said !
Got the top tub fitted today (not permanently) and its got better shut lines then my MG is that good or bad ?
Nick M
Got to say nick, there is a serious lack of pics of your car for your fellow j15 builders ;-)
I impressed myself today and took one with my phone ! but god knows how i get it onto the forum !!!
I will get my daughter onto it
Nick M
I must admit.....I've given up posting pics on the forum...keep getting an error message....you could do a blog of course ;-)
I will never finish it if i have to write about it as well !
