Finally got me engine out of the car, which is a pretty big stepping stone cos i can get it cleaned up and measure the thing for auto cad so i can
finally design the arse end of me chassis! hired a crane form hss for the day for £23 whichh aint too bad, not now its in the garge i can put a girder
across the roof and use me chain hoist if i need to shift it.
any hoo, heres a pic-
dirty engine
a quick scrape of the blackness reveals there is metal under there after all. should keep me busy for a while!
Russ.
what audi di that come out off. Like the idea of the audi 5 pot in a mid engine beast
was from an '86 coupe gt. 136bhp standard, and torque was awsome in the lower revs. not to mention the noise it makes! thats down to the fact
that only 2 cylinders fire together, the rest fire individually hence it sounds like a V8. plus since are spread equally round the crankshaft its
really smooth too. cant wait to get it running again, especially without an exaust!!
agree with the noise... need to post a wav when you get it running
drove one of them years ago....what a motor!, I shall watch with interest
Originally posted by suparuss
thats down to the fact that only 2 cylinders fire together, the rest fire individually hence it sounds like a V8.
yes m8 you are right about the audi, they do fire individually, i realised as i was pratting around with the engine and turning the crank. its the
equal spacing around the crank that makes it smoooooth. think 4cyls fire 2 - 2 though, unless the intake and exaust stokes alternate, not sure.
the body for me car isnt really decided yet, ill be using a lancia stratos windscreen and lights from hayabusa bikes, which may or may not give you an
idea.
intake and exhaust strokes alternate on a 4 cyl engine. so you have 1 cyl firing every 180 degrees.
