Anyone interested in my self built car?
Download video clip to view:
www.bickell.f9.co.uk/F1-2.MPG
It will take a while to download so be patient !
File is 17mb in media player format.
This is an old video and the bodywork is now on. I am waiting for the painter to start, then it is off to sva.
hm error 404 not found
Sorry about the error, but this may happen with some browsers.
Check my archive for a couple of older pictures
[Edited on 2/2/06 by nitram38]
Recognise the location from another video i have - thats where they/you build the lambo replica's isn't it?
Is that a honda engine you're using?
Ned.
That is my Friends Garage. He did a 4 wheel track for me. I built the car in a single garage at home!
Just uploading a photo now !
The engine is a bog standard SLi K-series 1.4 @ only 105bhp.
That is really cool! Where can we go to read more about the car?
Graber
The car was built from scratch by me. It took 6 years to build in my spare time. I work 84 hours most weeks so that is why it took so long. The engine
is a rear mounted transverse K-series 16V 1.4. Could be upgraded. It is a 2 seater in that there is a cramped but comfortable passenger seat behind
the driverseat/rollhoop. I am currently making a fake airbox to cover the passenger seat when not in use. It has inboard suspension front and rear
with unequal wishbones. It has fully adjustable front and rear anti-rollbars. The sidepods house the radiator and battery one side and the petrol tank
and small plumbed in fire extinguisher the other. Brakes are rover discs front and rear via a dual brake adjustable clevis. The hubs are custom made
cast steel from my own pattern. The clutch is a wilwood 'pull' slave and master cylinder instead of cable. Dash is the small spa speedo and
rev counter with full throttle gearchange and shift lights. Gearshift is a is a rod type on the lefthand side using rod ends and 10mm rod. Bodywork is
a mix of some fibreglass panels (long process) and aluminium. I have rushed the aluminium panels to get the car finished, but I intend to replace
these with fibreglass ones after sva. The headlights fold into the nosecone when not in use (manually).
I think that I have covered everything!
I will upload as many photos as I can.
Already planning the next generation, R1 powered with a lighter design.
Martin------nitram38
[Edited on 3/2/06 by nitram38]
has it been SVA'd yet?
Just about to get it painted, then sva
Are you painting it fully assembled?
No all the panels are on dzus fasteners and take about 5-10 minutes to remove. The aerofoils are bolted and take about another 5-10 mins too.
Like this a lot.
Very well done sir - big pat on the back deserved.
The chassis is already painted which only leaves the panels to do. The engine, brake bipes etc will not have to come out. And yes, the passenger and I
will be wearing helmets. They are caberg V2's that have internal sun visors like fighter pilots. I have also fitted a noise cancelling comms
system than has auxilary mobile and sat nav inputs. A transceiver can also be plugged in so that I can talk to friends in other cars/bikes etc.
Nice work.
