In regards to a middy what would make a better engine chocie, 4age or B16a ?
What's better, green or red, blond or brunette? Seriously, it depends on so many things that you aren't giving as background, that I
can't give you a black-and-white answer. What's your budget, background, experience, access to these engines in your part of the world?
Either engine can be made to work. There is no one answer.
Sorry to be terse, but these type of questions pop up all the time, and the answer, if there is one, is so subjective that it makes giving a real
answer all but impossible.
I used a Honda engine, but other people say others are "better." Well, there you go, it's all subjective.
One thing that can help make up your mind is the gear ratios. Work backward from your selected tire size and see what you end up with for top speed
and shift points. My book discusses this
[Edited on 4/27/07 by kb58]
Got to agree with him on this one. Personally I'd use a V6, so both are rubbish!
Also, in what way do you mean better? MPG, power, height,
gearbox ratios?
There can be only one.
BIKE ENGINE
Phil
.....and if youve got to go to the bother of building a mid engined car why setlle for anything less than a V12?
Ok then I have a few questions;
- Is either one more reliable for a racing platform?
- Which stock transmission would have the lowest possible gear ratios?
Kb58, why did you choose the h22? You must of looked at the 4age also.
Thanks guys, everyone here providing a great example of how independant we are. What one person likes, the next thinks is rubbish. That's the
beauty of building your own - screw what everyone else likes.
Why did I choose the H22? Back in 1995 it was the engine to have (IMO of course) To me (subjective) the Toyota didn't have enough power (define
"enough".)
Another variable I forgot is, what's the car for? You didn't say. If it's for racing, it really doesn't matter, both will be fine.
If you mean "real" racing, then I'd probably choose the Toyota because it was used in a formula car series. It'll cost a fortune
to build up, I suspect, but it'll rev to 10,000, and blow up in 10hrs, but you'll be rebuilding it more often then that anyway.
I discuss the Toyota in my book <cough>, saying it would cost too much by the time I built it up, and I was building a car, not an engine.
Keep in mind that your car will always weigh more than you wanted/expected, so having more power than you thought you needed will often end up about
right. I had the illusion that my car would weigh 1000lbs, hahahahaha, the reality is it's 1600lbs. Oh well.
[Edited on 4/28/07 by kb58]
Originally posted by Dean
The only v12 that is within reason is a jaguar and I like my engines running.![]()
There's nothing wrong with the 4AG. I used one in my Seven and am planning to use one in my mid-engined car, whenever i get around to it.
The 4AG in the Seven is making about 160 hp with carbs and cams. You can easily acheived 200 plus with a turbo, but just remember power = money.
Also, if you've considered using a Renault NG3 trans, there's a guy in Texas who's making an adapter for the 4AG to the french gearbox.
But i assume that you were thinking about using the Toyota trans with the 4AG and mounting it transverse.
Just my 2 cents.
~Rod
as some of the guys have stated it all dpends on things like present availability, budget, what are you going to use it for etc, my choice was a Mitzi
VR4 , 4G63 turbo 2ltr, reason, cheapest hp out there, i just spent $30g trying to get 300hp out of a toyota 3SGE N/A engine, and only just fell
short,and what we wound up with was a 9000rpm screamer that lives on the edge, but for $2500 i buy a stock 4G63 with 250hp and can acheive 300hp by
turning up the boost a little, simple choice realy, well to me anyway.
cheers Kaspa
[Edited on 29/1/08 by Kaspa]
