Hi everyone, greetings from down below
, South Africa, Cape Town. I love what you guys and gals are doing.
This is my first time posting on this forum, I've been reading all the middy posts for a while now. I chose this project for my final year of
study in industrial design. I know this is crazy, the car must be done in 4 1/2 months. I have designed most of the chassis and I've come up with
a design for the body already.
I am looking for the dimensions of the EJ20, Subaru engine, and I was wondering which gearbox I can use as a 2wd box. I saw a post on welding up the
internals of the 4wd box for RWD but not sure if it will work for front wheel drive.
Has anyone else done a scooby based middy succesfully?
Heres my concept design, my chassis design is on my other PC, I'll post it tomorrow:
Why not use the 2wd gearbox as its slightly shorter than the 4wd one
ho idea as to dimensions use to work on them but never measured one
Welcome.
Only Scooby based middy I've come across is the "Saker GT" http://www.saker.co.nz/ though I don't know which exact engine it
uses.
On your project 4.5 months is very aggressive to get a body made as well as the mechanicals. See "Fred W B" "Gaz 1977" and
"sgraber" posts which should help a lot as a start. On the positive side it isn't the most complex shape (in a good way - I quite like
it from that angle) which makes life a lot easier. Do you have lights in mind or will you be fabricating/faking some?
There is a Subaru 2wd gearbox but it's not as common obviously.
Originally posted by Gakes
I saw a post on welding up the internals of the 4wd box for RWD but not sure if it will work for front wheel drive.
Thanks for the swift replies guys.
zzr1100rick2 and iank Contributor
: I heard bout a 2wd box but I'm not sure if it will fit.
I planned to make the body out of hemp and a plant based epoxy resin.
RazMan Contributor: That post dont have any dimensions
OOOOOH, i just went through the "Subaru Powered Midy/Thoughts?" post and saw that the gearboxes look exactly the same except for the end
section that probably houses the centre diff.
Its not a FWD middy, its the subaru drivetrain's front section without the prop
[Edited on 11/1/08 by Gakes]
no idea about that as a material, but the I guess you still need a negative mould, so therefore a buck i.e. a full size car
body made of wood/chickenwire/polystyrene/plaster - or whatever will be needed to model the final shape and pull the moulds from. It's that bit
that takes the time if you want/need a quality final body.
You eco-warrior you no idea about that as a material, but the I guess you still need a negative mould, so therefore a buck i.e. a full size car body made of wood/chickenwire/polystyrene/plaster - or whatever will be needed to model the final shape and pull the moulds from. It's that bit that takes the time if you want/need a quality final body.
, good1
, I know. but I'm sure its a good learning curve
If you want the dimensions of a Subie motor there are several importers of used motors in Cape Town who normally have Subie motors in stock and who would be happy to let you measure one up.
Ivan
I'll go around tomorrow morning
if you need any measurements, just give me a shout.
not sure what i have in my photo archive.
look in "misc"
[Edited on 11/1/08 by meany]
Thanks Meany.
All hail Meany
You rock dude!
Here's a few pics of my chassis, some constructive criticism will be much appreciated:
[img][/img]
I'm no expert, but I am sure that you will need a LOT more triangulation in that design.
Hi gakes, nice to see another Sa on here
You might like to check out
this thread
and
this thread
Fred W B
[Edited on 13/1/08 by Fred W B]
OK,
The tunnel is probably doing nothing for the chassis, in fact the whole chassis isn't going to do much for the chassis until you put in some more
triangulation!
A front like the one on this would be a lot better. The blue lines show the bigger 4x2 14 gauge tubes around the engine bay. A spaceframe rear is
certainaly possible.
Or a variation of this perhaps?
Thanks for the advice guys
, I was going to add a few cross members into the design, but its still a "work in process" project. I have
another idea that could probably work much better with less tubing. I'll get cracking and post something later.
does anyone have the track width that goes with the EJ20
does anyone have the track width for the ej20?? Meany do you perhaps have those details please
[Edited on 13/1/08 by Gakes]
