just wondering what opinions are (or experience) on very thin walled steel tube, i plan on using 32mm round erw with 0.91mm wall thickness for my
chassis, its a bike engined car so i want weight low obviously, but would like to get as close to true space frame as poss for stiffness, hence lots
of light tube rather than small amounts of heavy tube. i know welding could pose as a probelm, but im very competent with the mig so can get around
that, any other probs come to mind ie- is the tube TOO light??
ive atatched a picce of the part of the chassis (not finished obviously) tis mid mounted bike engine)
Russ.
As an ex pro welder, the strength of steel is often underestimated, you should be fine as long as non of the lengths are particularly long and
everything is triangulated and load paths are directed at multiple joints
Your front end, which needs to be the strongest has no triangulation, but as you said its not finished yet - looks really good
I think the biggest problem will be the practical aspects.....tube that thin will need meticulous joint preparation...and obviously very good
welding...
The theory is right .....bigger diameter and thinner wall is much stiffer than smaller diameter...
Good luck and keep us informed.
When I used to make a lot of spaceframes the thinnest we would normally use was 18g which is about 1.2mm IIRC....
Consider making the tube thinner and thinner, and adding more and more of them. Eventually you converge to a monocoque shape made of sheet material
instead. Have you considered making the central tub at least out of sheet, with a space frame box at front and rear?
Am conspriring to do this sometime in the next few years with a bike engine also. Lotus' elise is an interesting place to start - you may want to
check out this URL.
http://www.sandsmuseum.com/cars/elise/thecar/chassis/
You dont necessarily need to use all aluminium - this example of a 68kg chassis may be a bit overdone. If your bike engine has more go than the rover
engine the elise runs, you're probably in good shape.
I reckon the hayabusa engined concept car from the tokyo 2001 motor show might get you thinking too - try a google search on "GSXR/4" or go
to
http://www.graziosi.net/mario/gallery/GSXR/gsxr4_1
Good luck and let me know what you come up with - you may save me a lot of work down the track!!!
thanks for you input, feel a lot better now
its all a bit rough a the moment i dont know the actual width yet cos quaife wont send me a drawing of their diff, and im trying to get some
dimensions for the windscreen from some lancia stratos owners, then i should be able do some final designs!
its and interesting idea aus-sambo but im not sure i could gain anything without converting entirely to an alluminium chassis, steel isnt strong
enough in really thin sheet, tho you have put a bee in my bonnet about using stressed skin construction around the inside of the cockpit, i can save
on a few tubes, and on alluminium for the interior, so that is worth looking into.
building the car will be another matter though, i get my new house (with a workshop)in a couple of weeks so after moving the tiny bathroom into the
one of the bedrooms, using the bathroom as a staircase into the loft which ill convert into a big bedroom, and fit a new kitchen not to mention
decorating! then ill be able to start the car
providing i dont decide to sell the house which depends how much the value goes up
cant wait.
Russ.
