Hi All,
I'm looking for good/reliable source for oval and aero section tube ( aircraft grade steel). Any suggestions?
Thank you
Ted
www.aircraftspruce.com
Expensive.
An alternative is using round section then cover it with an aero-shaped cover. Aircraft spruce may have that too... someone does...
Thanks a lot! I'll go check their site now!
Ted
[Edited on 10/12/03 by Tudor (Ted) Miron]
This is another American based company - http://www.chassisshop.com/
Use their online catalog - It's a PDF - Choose the Tubing section. The aero (streamline) tubing is on page 2. Prices are listed.
http://www.chassisshop.com/pdf/tubing.pdf
I don't know if their prices are any better than Spruce, but A-Spruce is sooo expensive! I have ordered the chromoly tubing from Chassis Shop and
it is of high quality.
Graber
Thank you Steve
Ted
