Hi all,
I am doing the last bits getting ready for iva. My chassis is an early luego one without an assigned chassis number. I need to make one so
that I can get insurance to drive the car to an mot station locally so that I can check immissions and brake performance then drive to iva.
What format should I use for the number plus anyone recommend the best place to get the plate?
I have a v5 for the sierra donar and I did an engine change on the paperwork to the st170 engine I have. I want to either get an age related or new
reg any tips how to avoid a Q?
Dave B
I am in exactly the same position with my Luego Chassis. I literally have nothing in regards to chassis identification or anything. I will be
watching this thread with interest.
Why do people feel the need to avoid a Q-plate?
Originally posted by Dave Bailey
I have a v5 for the sierra donar and I did an engine change on the paperwork to the st170 engine I have. I want to either get an age related or new reg any tips how to avoid a Q?
Dave B
Write to the dvla and ask them To issue you a vin
Rich
When i built my Viento I made my own number up and sent a letter to DVLAasking them if it was sufficient. They sent a reply saying it was OK so i
stamped a plate with the number on it and then welded it to that chassis and that wasa fine for SVA!!
If you dont have the donor V5 then it will be a q plate unfortunately.
cheers Colin
As you are in Portsmouth take a trip to the DVLA office and ask for one as I did just before Christmas.
They won't give you one but send you away with some forms instead - Built Up Vehicle Report form V627/1 & 1st Registration Application V55/5.
Fill out as much as you can on V627/1 and the few boxes that you can on V55/5 (Manuf., Body type, Wheelplan, Type fuel & cc). Go back to the
office armed with these (and lots of pics if possible) and ask them again for a number but be prepared for a completely different process and set of
illogical hoops to jump through!
Good luck ...........
I sent a letter to the local dvla saying I was building a kitcar and could I have a chassis number please.
Three weeks letter I vin number and covering letter.
Job done. Less hassle than inventing one and then playing tennis.
I made one up and put it on the SVA app form and it was fine. Just combi of numbers and letters, cant remember how many etc now.
I stamped it on frame and stamped it ona rivetted on plate in engine bay.
It was a meaningful combi, not random.
AFAIK you can't legally drive to an MOT station before the IVA test.
Right hand column, nine down.
http://www.shedworks.eu/hints.html
Thanks all.... The letter was particularly of interest..... What a coincidence that your name is Locoster... What odds would you get on that? :-)
Dave B
Hi all,
I am doing the last bits getting ready for iva. My chassis is an early luego one without an assigned chassis number. I need to make one so that I can get insurance to drive the car to an mot station locally so that I can check immissions and brake performance then drive to iva.
Dave B
Hi!,
I have a friend who has an MOT station and I wanted to get it there to do an emission test and set the lights and the brakes up before I pin the
bias bar.... Thanks for the advice though of not getting it on the system....
I have a V5 for the domor and the V5 reflects the number of the ST170 engine.. I did an engine paperwork change before the car was scrapped... I
don't have a receipt for the donor it was 'given' to me... so I may be stumped there...
I too bought an unstarted kit from ebay but I do have the original reciept from Luego plus I have the receipt from the guy I bought it from...
Ref the Vin number.. I mailed the DVLA nd they told me to write to the nearest DVLA office which is Portsmouth to get a number issued.. This seems to
be what others have done... I may be doing Ben and injustice but I just expected it to be difficult to get hold of anyone at Luego especially as I was
after something for nothing!!!
What do you think? Do I have a chance of an age related plate?
Dave B
Hi!,
I have a friend who has an MOT station and I wanted to get it there to do an emission test and set the lights and the brakes up before I pin the bias bar.... Thanks for the advice though of not getting it on the system....
I have a V5 for the domor and the V5 reflects the number of the ST170 engine.. I did an engine paperwork change before the car was scrapped... I don't have a receipt for the donor it was 'given' to me... so I may be stumped there...
Ref the Vin number.. I mailed the DVLA nd they told me to write to the nearest DVLA office which is Portsmouth to get a number issued.. This seems to be what others have done... I may be doing Ben and injustice but I just expected it to be difficult to get hold of anyone at Luego especially as I was after something for nothing!!!
Dave B
If you have the V5 and the main components are from the donor (brakes, gearbox, diff, engine) not sure how you could validate the non serial numbered
items, then you can get an Age Related plate. On mine the engine wasn't part of the donor but everything else was and I got an Age Related Plate.
The V5 for the donor was transferred to my name before the car was scapped although the DVLA will do this for you retrospectively if need be.
HTH's................... Neil
I did MOT my car before IVA, and agreed, you will have to MOT it every year (so that's three extra MOTs you could avoid by not MOTing it).
HOWEVER, it is a good opportunity to get a legal (I obtained written confirmation from VOSA that it is legal) test drive in before IVA and to get an
outsider to check over the car - not to mention checking emissions which isn't really something you can do yourself. If it fails emissions,
better to find out at a £50 MOT than a £450 IVA.
So it really comes down to whether you think you need the test drive, emissions testing and extra checks that an MOT will get you, and whether
that's worth the £150+ extra it will cost.
Well 10 days later and I have had a chassis number allocated by the Portsmouth DVLA office... They have sent a form with the number on it... I need to
stamp the number in the chassis then get a garage to sign the form and I have to return it...
Has anyone stamped the number in the front of the chassis where the rack is mounted? The steering rack is mounted to a plate rather than try to stamp
the box section......
thanks
Dave B
Has anyone used this chassis plate?
Sorry it's a bit small.....
Dave B
Just reading the IVA manual and it states that the VIN number should be securely attached... I though the number had to be welded to the chassis or
stamped however the manual states bolted or riveted.
Dave B.
Not sure about where it needs to go for IVA but if it's OK the top diff mounting plate is pretty solid
one of my fail points on my IVA - I had stamped the box section under the nose cone as I had no chassis visible under the bonnet on the right hand
side. The examiner said it was a fail because it couldn't be readily seen by removing the bonnet. I ended up cutting an oblong out of the ally
cladding which was above my pedal box, then stamping the number on the chassis member there. I also have a plate similar to yours (but with the Luego
Logo) riveted to the scuttle.
In addition to the plate, you will also need to put a VIN on a chassis ( or other non-removable part ) as stated in the manual:
1. The vehicle must be fitted with a manufacturer’s plate, in a conspicuous and readily accessible position.
2. The manufacturer’s plate must be made of a durable material.
3. The manufacturer’s plate must be indelibly marked with the manufacturer’s name and the vehicle identification number.
4. The manufacturer’s plate must be fitted to a part of the vehicle that will not be replaced through normal use.
5. The Stamped in VIN must be marked on the chassis, frame or other similar structure which is not easily removable, on the right hand side of the
vehicle. (see note 3,5 & 6)
6. The Stamped in VIN must be placed in a clearly visible and accessible position by a method such as stamping, etching (metal chassis) or embossed,
moulded into the structure (glass fibre or carbon fibre chassis) so that it can not be obliterated or deteriorate.
7. The VIN number must consist of 17 digits (except for mass-produced vehicles see note 4)
8. The information must be shown in a single line. (in the case of a mass produced vehicle the use of two lines is permissible)
Originally posted by stevegough
one of my fail points on my IVA - I had stamped the box section under the nose cone as I had no chassis visible under the bonnet on the right hand side. The examiner said it was a fail because it couldn't be readily seen by removing the bonnet. I ended up cutting an oblong out of the ally cladding which was above my pedal box, then stamping the number on the chassis member there. I also have a plate similar to yours (but with the Luego Logo) riveted to the scuttle.
5. The Stamped in VIN must be marked on the chassis, frame or other similar structure which is not easily removable, on the right hand side of the vehicle. (see note 3,5 & 6)
6. The Stamped in VIN must be placed in a clearly visible and accessible position by a method such as stamping, etching (metal chassis) or embossed, moulded into the structure (glass fibre or carbon fibre chassis) so that it can not be obliterated or deteriorate.
Thanks Guys... Steve where did you get the Luego logo tag?
thanks
Dave B
Having a Q plate isn't all bad news.
When it reaches MOT time in 3 years the tester can only test for smoke on start-up and no other emissions - ask me how I know!!!
HTH.
Cheers,Pewe10
thanks
Dave B
