Sierra steering column bearing
gregf27 - 19/4/11 at 10:00 PM
Can anyone put the link up to previous threads for the bearing mod that replaces the plastic bearing on the steering column?,
I cant remember the bearing supplier or part number , think it cost about a tenner?, am sure someone posted a "how to"
on here, cheers
Tris - 19/4/11 at 10:06 PM
Here you go
http://simplybearings.co.uk/shop/p22810/SBPFL205+Oval+2+Bolt+Pressed+Steel+Bearing+Housing+with+25mm+insert/product_info.html
snapper - 20/4/11 at 05:21 AM
You retain the plastic inner bearing, the one with the triangular hole for the column, it's a fraction to big, so fit it in a drill, clamp drill in a vice, wrap emery clth round plastic and turn on drill, keep checking until it fits in the bearing, the bearing has a grub screw to fix the plastic insert.
andrew.carwithen - 20/4/11 at 07:28 AM
Carried out this mod on my Cobra build.
Google Wiki 'how to build a Sumo'
And look under 'steering'
shows how to do the bearing mod (I know its on a Cobra but the principle's the same.)
[Edited on 20/4/11 by andrew.carwithen]
jossey - 20/4/11 at 08:03 AM
i agree with tris.
i use that bearing and its really good.
RichardK - 20/4/11 at 08:39 AM
Planning to do this myself so thanks for the link.
Rich
stevegough - 20/4/11 at 08:56 AM
here's mine (also from simply bearings).
completed + painted mount - also showing the steering couplings.
40inches - 20/4/11 at 09:51 AM
Originally posted by Tris
Here you go
The 1" version fits easier, I fitted the 25mm one and had to skim the plastic bit, it pushes into the 1" unmolested
gregf27 - 20/4/11 at 09:28 PM
That was it!, thanks everyone
