Changing over to Sierra LSD and disc set up on the rear of my kit.
I need to purchase the left and right nuts for the halfshafts hub.
Don't have any details on dates of parts now being fitted.
Anybody know date range or part numbers of the nuts I need?
Are these still available from Ford? Any other supplier?
Ta
Should get them with wheel bearing kits which are pretty cheap and easily available for your friendly motor factor if you cant get them separately.
Found this info on another site
Ford Sierra 41mm hub nut x2 (211205, 350906) Ford 9.42
http://www.btinternet.com/~richard.d.miles/costs.html 7th item down
[Edited on 8/1/12 by RichardK]
If you buy a set of wheel bearings at the end, i would recommend buying them from this seller:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Very good price and quality (Timken bearings, not Chinese crap) and top service.
You can buy the nuts individually from Westfield on their online store
Thats a strange link from DRCorsa, I've never come across a wheel bearing kit that never had both left and right hand nuts supplied
