As per the title my locking Wheelnut key has broken this evening. Anyone had this problem as I need to get the wheels off?
Ideas / suggestions please!!!
Thanks.
Have you the key code ? If so approach manufacturer for a duplicate key.
Failing that - put close fitting old socket over nut/bolt and weld through square drive hole - use ratchet to undo.
Hope that makes sense.
Rob.
You can get locking wheel nut removers from Machine Mart, failing that you can get a socket slightly smaller than the nut and hammer it on which should allow you remove the nuts but you have to be carefull of damaging your wheels.
Depending on the type, I've heard of Patented Gator Multi-Size 3/8"'-Drive Socket - Fits SAE &' Metric 5/16"' to
13/16"' | eBay
ntitled Document
ocument Title 3
ocument Title 1
ocument Title 1
ocument Title 1
ocument Title 1 being used to get them out.
I tried the slightly oversized socket and hammer option........worked a treat!!! All 4 lock nuts now removed!
Thanks all. Off to buy some new ones!!!
Best method to remove depends on the type of lock.
Most common method is to drive a 12point socket on. You need one that just too small and you don't mind busting if all goes wrong. This
won't work on locks with a loose ring around it and you'd have to remove the ring first.
edit... must type faster.
[Edited on 17/3/14 by adithorp]
