I have one set of mild steel camber adjusters available if anyone would like a set?
These replace the aluminium rally design/GTS ones.
Made to standard dimensions, turned section is 63.5mm long and 21.75 diameter.
Thread M18x1.5.
25mm hex
£25 set
I can make more sets if anyone needs some.
U2U sent.
Flak, How much to make a set with 5mm holes drilled through the end rather than a hex section? i.e. made from round bar instead of hex.
ATB Dan.
