I have stripped down the R1 5VY engine that was originally dry sumped. As a result I have lots of bits for sale.
The gearbox has gone already, so has the clutch and basket.
So if anyone wants any bits please let me know.
Ed
I'd be interested in any sensors/electrics you have spare.
adrian
Not a lot of loom there, but all the normal sensors that come with the engine are there, neutral, crank etc.
I'll keep em for you.
speedo sensor? not sure if there is a problem with my sensor or my healer or my connections or some interference but if it's up for grabs i'd be interested
Sensors would be great. Just want spares for touring. Don't need loom. Is there an ECU? let me know what sort of money you want for them.
adrian
Might be interested in the Barrels and Pistons if you've still got them
Will have barrels and pistons.
No ECU afraid.
I will contact everyone who has expressed interest as soon as I'm sorted, which will be a week or so.
Not looking for much money, just to recoop a bit. I usually see what things are on Ebay and half it.
Ed
Also interested in the starter/generator bits (stator coil in particular) and the regulator/rectifier.
I assume you don't have a standard sump for it, given the other post?
adrian
Noted,
and correct, no sump.
Also interested in crank cases if you have them too
Interested in the cam cover if you still have it. Thanks
