plastic insert for gear knob wanted
gregf27 - 25/6/13 at 08:08 PM
I am replacing the gear knob on my F27 to a Richbrook one , but need to replace the plastic tube insert as the old one had split, does any one have a spare one lying around ? think its 8mm
or know where I can get one from - tried e-bay
thankyou
pewe - 25/6/13 at 08:39 PM
I've used body filler paste(suppose you could also use JB Weld or similar) on a couple of gear-knobs.
Wrap the gear-lever in cling-film making sure it comes quite a long way below the thread.
Whack some mixed filler into the knob, trying to make sure it goes in all the way, then place it over the gear-lever, lining it up how you want it.
Simples....
HTH.
Cheers, Pewe10
doobrychat - 25/6/13 at 09:04 PM
8mm nylon bar and drill it...
wilkingj - 26/6/13 at 08:20 PM
Heat gear lever with small torch. Smear hot melt Glue on Lever, fit knob over the top and position. Leave to cool.
I did this with a Pool 8 ball, it never moved in 6 years.
Also easy to remove by re-heating the lever again.
Do NOT put HMG in the hole in the ball / knob, it cools too quickly when it hits the cold lever.
This works well and is easy to remove.
gregf27 - 6/7/13 at 08:44 PM
Thanks for the replies to date,
but all I'm after is the plastic insert, as I still want to be able to remove it quickly if needed.
can anyone help out?
ta
