Acewell all working now
whitestu - 18/6/08 at 08:42 PM
I went out and calibrated my Acewell tonight, checking it against my satnav.
I started at a radius of 513 based on Coozer's advice - thanks, and after a bit of trial and error ended up with a radius setting of 480 which left the Acewell reading about 74 at 70 on the satnav.
All the guages work well, and even the fuel gauge seems to work with the Sierra sender, although the tacho seems a bit jumpy on the MJ output.
Thanks to Russ as well for supplying it. I'm very pleased with it and my dash looks a lot better.
Stu
richardh - 18/6/08 at 08:43 PM
well done
omega0684 - 18/6/08 at 08:57 PM
any pictures?
gy351100 - 18/6/08 at 09:48 PM
hi stu
You say your fuel gauge works ok with a Sierra sender.
What fuel gauge is it
I also have a Sierra sender and am trying to find a fuel to suit
cheers
Keith
Danozeman - 19/6/08 at 07:05 AM
How did you get the tacho to work with MJ? Mine will work sometimes but mostly not?
whitestu - 19/6/08 at 03:22 PM
You say your fuel gauge works ok with a Sierra sender. What fuel gauge is it
I'm talking about the fuel gauge in the Acewell unit.
Just connected it to the tacho output on the MJ - as I said in the post it is a bit jumpy so not sure how accurate it is.
