As title.
I think mine will be about 2 meters.
62" at the widest.
about 187cm across rear arches
wide for a seven type.
About 1550mm ish.
as wide, and as long as a ford transit...
Mine is 65". Plus 4 body, (46" and two rear arches at 9.5". Ray
[Edited on 8-3-07 by Chippy]
before you all grow wider and wider
2550 mm is de max!
Mine will be around 1730 mm
IRS (diff sierra) with 195/60R14 on 6J ET 38
1800mm
1500mm / 59" (book chassis, Escort live axle)
