Does anybody use this bracket:
http://www.caterhamparts.co.uk/product.php?id_product=2415
It looks perfect for a 40a denso alternator (brise?) on the inlet side.
As the holes in these size are not aligned (bottom holes are aligned, but not upper ones) it is not easy to make a bracket and this is not very
expensive.
Thanks!
I made one from billet alluminium here's a pick, just spent time and a lot of elbow greese getting it done hopefully you can see it in the pic
[img]
Engine Bay cooling pipes
[/img]
I've got one in the garage I never used if you want one.
Ģ55 delivered sound ok?
Paul.
[img]
Engine Bay cooling pipes [/img]
I found a picture that looks promising!
Mine is not really a brise alt, it's a daihatsu hijet 40a Denso thats look veeery similiar.
Just found another pic, I have used the bottom two holes and made a bracket for the bottom too from 4mm steel strip
[img]
ND Alternator
[/img]
