zilspeed
| posted on 18/9/11 at 08:05 PM |
Sylva :- plus ça change plus c'est la même chose
It seems that with the supply of donor parts drying up for front suspension, Sylva have made the decision to use an alternative upright. Those capri
escort struts weren't going to be around forever.
And what is this new 21st century innovation bourne of year of computer aided design and R&D ?
Why, it's the good old Herald upright !!!
Just like it always should have been...
[Edited on 18/9/11 by zilspeed]
| posted on 18/9/11 at 08:18 PM |
If it was good enough for the Lotus 7, then it's good enough for a Sylva...
It's Evolution Baby!
mark chandler
| posted on 18/9/11 at 08:22 PM |
Also I believe the reliant kitten
zilspeed
| posted on 18/9/11 at 08:38 PM |
Look at it.
It's like Zola Budd compared to a Sierra part which is more like Hattie Jacques.
In term of mass, I reckon it's where a front upright should be, but oh no, the kit car manfacturers had to use the part available with the
donor.
If this is a result of there being no Sierras / Capris / escorts left, I for one am all for it.
MikeRJ
| posted on 18/9/11 at 08:47 PM |
I presume these are still being manufactured then? What sort of price are they sold for?
zilspeed
| posted on 18/9/11 at 08:51 PM |
I just checked.
Canley Classics charge £85 plus vat per "vertical link" as it's called.
It's £325 for a front suspension set inc hubs, arms atc.
Significant on a budget build, less so if you're into the very high thousands anyway.
Having said that, if you have the talent and the time, fabricated uprights are perfectly possible.
I am missing at least one of those skills...
iank
| posted on 18/9/11 at 09:28 PM |
From this thread (random memories and search again) http://www.locostbuilders.co.uk/viewthread.php?tid=36901
Mad Dave seems to know who still makes them. IIRC Caterham have a slightly improved design without the troublesome trunions.
Anonymous
iank
quote: Originally posted by zilspeed
Look at it.
donor.
+1
Anonymous
JacksAvon
| posted on 18/9/11 at 11:11 PM |
Triumph Herald/Vittesse hubs are used on Mallock race cars
RK
| posted on 18/9/11 at 11:17 PM |
It looks an awful lot like the MX5, which just looks perfect on these things. Mine were not that cheap though from the scrappies when I started my
build.
flibble
| posted on 19/9/11 at 07:50 AM |
Doesn't look like that one has a trunion either, although it's mostly obscured so not sure??
D Beddows
| posted on 19/9/11 at 08:43 AM |
No need for trunnions any more as they've been available to buy off the shelf to use with spherical bearings for a good few years now. No idea
why more people don't use them as they're as close to ideal for the job as makes no difference AND you can buy hubs for them with a Ford
PCD if you don't want the Triumph PCD.
motorcycle_mayhem
| posted on 19/9/11 at 09:18 AM |
I'm (for reasons that are - like others - intrinsically complex) looking at replacing the Fiesta/Capri set-up on the Riot. Currently, having
massive steel hubs, etc., on a sub-400Kg car is a bit much. I also need to increase the front track for perverse reasons.
I'm probably going to lighten the Fiesta gear, get hold of an alloy hub (difficult, since all GP4/Capri dimensions it seems), and make longer
wishbones....
What I'd love to do is change it all for Cortina. I've seen RMD alloy Cortina uprights with the Metro balljoint screwed in the top - makes
me shudder, but then I'm like that. That solution puts the height of the upright where the Escort one is (good, because changing the front
wishbone pivot positions on a Riot isn't trivial), but with the stub axle a tad lower, suiting my application perfectly. It's ideal,
combined with other stuff I've got here..... but I haven't managed to contact any folk who've done it. Some very nice sites on the
web with build diaries depicting the Raceleda uprights (pre-RMD) with said modification - but my email contact has not succeeded. Their uprights might
have failed I guess....
Might consider he Herald then, it's the future.
britishtrident
| posted on 19/9/11 at 10:55 AM |
The geometry is good.
They also have used in F1, Le Mans and the Indy 500 back in the year yonk as well as on the front of the Lotus Espirit.
Most actual Triumph Herald vertical links were cheap and nasty versions that were cast in one lump, the advantage of the puka Alford and Alder type
is they have bolt on steering arms and disk brackets and stub axles..
The trunnion isn't a problem if it is kept oiled -- nb Oil not grease.
[/I]
