Findlay234
| posted on 25/10/02 at 02:41 PM |
question for alan b
with your 4age engine what was the mileage when you got it and what was its condition???
that plastic cover over the spark plug valley (between cam covers)....... is that important???
i ask because i went to see about buying an mr2 the other day and it didnt have one.....
cheers..
Alan B
| posted on 25/10/02 at 02:53 PM |
160K miles...runs well, good compression, but will rebuild later.
The cover supports the plug leads I think...not much other purpose really...
I think mine was sheet metal actually...dead easy to make if you wanted...
Findlay234
| posted on 29/10/02 at 08:40 AM |
another one.....
where is the knock sensor??? i think mine might be playing up.
Alan B
| posted on 29/10/02 at 01:28 PM |
Hmmm...don't know off hand.
I'll post back here when I know.
Unless anyone else wants to jump in
Spyderman
posted on 29/10/02 at 04:16 PM |
Just guessing
Not too sure about this but isn't that the job of the exhaust gas sensor?
Terry
interestedparty
| posted on 29/10/02 at 05:38 PM |
Terry
Knock sensor is there to detect pre-ignition aka pinking or knock and will be on the block somewhere. Exhaust gas sensor detects the oxygen level in
the exhaust and allows the ECU to adjust the air/fuel mixture
John
As some day it may happen that a victim must be found,
I've got a little list-- I've got a little list
Of society offenders who might well be underground,
And who never would be missed-- who never would be missed!
Findlay234
| posted on 29/10/02 at 07:15 PM |
what does it look like, ive got the haynes manual in the post but id like to just have a check over it now.
theconrodkid
| posted on 29/10/02 at 07:47 PM |
it looks like a temp or oil pressure sendershould have 2 wires on it near the top of the cyl block,to check if its working let the engine tick over
and tap rapidly near it with a small hammer,the revs should go down if its working
