Alan B
| posted on 9/1/04 at 01:59 PM |
Minor updates
To my site...including a guest book...
Be gentle...
http://www.desicodesign.com/meerkat/
violentblue
| posted on 9/1/04 at 02:13 PM |
I've been looking over your site, catching what I missed the first time over. Glad you decided to lose the frog eyes.
the probably would look OK if they were inset rather than surface mounted, but I wonder if round headlights work with the body style you got going? I
guess If they're in a pop up cluster it would.
a few pics of my other projects
Alan B
| posted on 9/1/04 at 02:27 PM |
Yeah, that was the trouble..I couldn't inset them...no room.. ..pop ups seemed the best way out.
I will mould it just as it is and figure the lights later, but there will be plenty of room for pop ups.
sgraber
| posted on 12/1/04 at 10:58 PM |
I looked at your current work. Very nice!
With the clean lines that the pop-ups allow you to have, I agree that it's a good design choice.
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
internetautomart
| posted on 13/1/04 at 02:18 AM |
have you thought about frenching the headlights behing a sheet of clear lexan?
maybe use an h4703 unit?
Let me know if you need parts in the US
Alan B
| posted on 13/1/04 at 02:25 AM |
Yep...first choice, but sadly no room....not at a legal height....
What's the h4703?
internetautomart
| posted on 13/1/04 at 02:32 AM |
the low beam bulb/assembly used on the 93-97 camaro
90-96 cutlass supreme
90-96 pontiac grandprix
very short only about 1-1 1/2" tall and only 4" wide
I was gonna install a pair on my impala to replace the quad headlights and create a ram air sytem but never did
sgraber
| posted on 13/1/04 at 03:34 AM |
But how deep? I think that Alan's project has a severe depth limitation in the Z axis. (As will mine)
Graber
internetautomart
| posted on 13/1/04 at 03:36 AM |
IIRC about 6" with a 90* bulb connector
internetautomart
| posted on 13/1/04 at 03:52 AM |
oops the bulb # is h4351 low beam
Alan B
| posted on 16/1/04 at 03:51 AM |
Added some pics of some paint applied....shape looks more defined.
ned
| posted on 16/1/04 at 11:50 AM |
Alan,
The shape looks good as does the finish (well, from the quality of the pics!) though you appear to have left the headlamp recess' smooth? or
were the previous pics i saw paintshop pro or something and you haven't started on that yet?!
Ned.
beware, I've got yellow skin
Alan B
| posted on 16/1/04 at 01:20 PM |
Ned, the front arches are smooth. The headlight pods you saw were real, but I ripped them off and and smoothed it flat again,...they were Ok from some
angles, but a bit too froggy from other angles.
Actually, the first coat of paint isn't as goood as it looks as it does it's sealing in the first coat or two and is a bit
blotchy....however I'll stil be filling a little so there will a lot more to go on yet.
