ceebmoj
posted on 24/2/04 at 08:54 PM |
drive shaft
Hi
Got my engine the other day (bike) and the sprocket is further over to one side than expected I was wondering what sort of angle it is acceptable to
put on a drive shaft. I am building mid engine so it is from the engine to the diff and relatively short 30/40 cm from centre of the joints.
Blake
Ps I have also posted in the middy bit as well
ProjectLMP
posted on 24/2/04 at 09:36 PM |
The other option is to mount the diff off centre. This is pretty much the setup with the powertec quaife unit. Means you need different length drive
shafts. From a balance perspective it would probably be better to try and get the engine centrally located rather than the diff.
Home of the Astronomicalcost Mid engined LMP project
