matnrach
posted on 26/10/07 at 08:38 PM |
Mid mounted A series engine
Hi ,
Anybody have a car with a mid mounted A series engine (GTM, Blitz, Terrapin etc) that has a solid, quick gearchange?
Mine is not so good (not very precise and quite slow) so looking for ideas.
Pics, advice greatfully received.
Thanks.
daviep
posted on 26/10/07 at 09:10 PM |
I built a buggy with a mini subframe/engine at the rear, used a solid linkage bent underneath the engine. The gearlever was the standard lever which
was stripped and rebuilt to change the reverse position. The gear change was quite positive.
kb58
posted on 26/10/07 at 09:30 PM |
Not A-series, but I use push-pull cables for shifting a mid-mounted Honda Prelude assembly.
[Edited on 10/26/07 by kb58]
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
minitici
posted on 27/10/07 at 09:10 AM |
I have a couple of GTMs, the 'standard' gtm linkage is reasonable but only if you have lots of engine/gearbox steadies fitted (otherwise
engine tends to move instead of finding the gear).
I made a similar linkage for my A-series powered single seater.
http://www.westhouse.plus.com/hawke12.htm
matnrach
posted on 27/10/07 at 09:34 AM |
Thanks minitici,
I might try this approach.
As you say its all about removing lost motion.
