<<  1    2  >>
Author: Subject: Creating Holes in Aluminium
Simon
posted on 30/1/05 at 08:05 PM Reply With Quote
If you know exactly where you want the holes to go, you could take the panel to a company like Sciss in Staplehurst and they'll water laser cut them.
Very, very accurate.
We've used them for cutting Phosphorous bronze plate 3/4" thick!!
http://www.sciss.co.uk
Simon
[Edited on 30/1/05 by Simon]
irvined
posted on 31/1/05 at 01:26 PM Reply With Quote
Thanks Guys, will give the hole saws a try and failing that chain drill.
nick baker
posted on 3/2/05 at 09:49 AM Reply With Quote
Lubrication....
as noone else seems to have mentioned it.....
When cutting with a hole-saw or drilling in Aluminum DON'T use the oil that you'd usually use on Steel...
The best stuff is industrial alcohol, and the cheaper alternative is AJAX window-cleaner (or a similar 'squirt on, wipe off' kind of stuff).
The difference is stunning.
Maybe everyone knows that little trick already... maybe not.
hope it helps somone anyway..
N
posted on 3/2/05 at 10:30 AM Reply With Quote
I used WD on mine as it was there when I was doing the job. I have seen people recommending paraffin (white) as a lubricant for working with aluminium.
<<  1    2  >>
