Matysiak
posted on 25/11/08 at 07:24 AM |
Wilwood 1 inch
In a moment of madness, i bought a wilwood 1 inch tadem master cyllinder to replace my single outlet master cylinder without doing a whole lot of
research. There were two reasons. One, the unit being a single cicuit didn't leave me feeling very safe and the other was the pedal travel was
far too long, almost to the floor long.
The car has triumph herald brakes with rear drums
Anyway, after reading through the site, no one is using a 1 inch master cylinder. Will i be OK with this upgrade or not?
posted on 25/11/08 at 08:11 AM |
What you needed was Triumph Spitfire 1500 dual circuit master cylinder.
All Triumph Herald/Spitfire master cylinders are 0.7" bore with a 1" master cylinder you will require more than 50% extra force on the
pedal to stop the car in the same distance..
Caterham also use a 0.7" bore cylinder on the models with Triumph brakes.
If you had long pedal travel with all Herald brakes bits it indicates something is wrong --- ie probably a mechanical fault eg a caliper with a seized
piston, flexing pedal box mountings flexing, or rear brakes not correctly assembled.
[Edited on 25/11/08 by britishtrident]
Matysiak
posted on 25/11/08 at 02:17 PM |
Thanks for the feedback. Now that i have paid 100 pounds for it, do you think it is useable?
Mal
posted on 25/11/08 at 05:36 PM |
Try to find out what applications it is normally used for so. This might help you to sell it.
Rally Design may be able to help you.
