Hadders
posted on 7/12/08 at 06:14 PM |
WTD - Borrow 20mm drill - Herts
Does anyone have a 20mm drill and pillar drill/lathe that i could use?
I'm fitting a breather to my cam cover. It's a -10 JIC fitting so needs a 7/8" thread tapping. The tap says use a 20.4 drill but my
pillar drill only goes up to 16mm. Can anyone help? Just need to dill one hole!
I'm in St Albans, Herts. but happy to travel.
TIA
Ben
bob tatt
posted on 7/12/08 at 06:44 PM |
what about a local engineering firm the one near me is really helpfull and will drill the odd hole for me for the cost of a pint give that a go you
never know.
dave r
posted on 8/12/08 at 07:00 AM |
got one in rushden northants if no-one closer
dave
londonsean69
posted on 8/12/08 at 08:47 AM |
TIA
Ben
You need a blacksmiths drill.
They have a 13mm shank but you can get them in loads of sizes, upto 25mm or so.
I have just got 19, 16.5 and 17.5mm off of ebay, they seller is called UKDRILLS, they are about £5.49 including the postage.
Sean
carlknight1982
posted on 8/12/08 at 10:28 AM |
im in letchworth and im pretty sure i have a 20mm holesaw drop me a u2u if u still need help
Andybarbet
posted on 8/12/08 at 07:31 PM |
Im in stevenage, let me take a look if you still need help ?
I will take a look at work too (letchworth)as we have an old school mill and loads of drill bits etc, work for inlaws so shouldnt be a prob.
Hadders
posted on 8/12/08 at 10:51 PM |
Thanks for the responses guys.
Sean - that's excellent. Will check them out.
Carl and Andy - Much appreciated. I'll check out drills first and get back to you later if necessary.
Thanks again
Ben
londonsean69
posted on 9/12/08 at 11:56 PM |
Thanks again
Ben
Biggest I got from them so far is a 19mm, you can borrow if you like (will post it but you still need to give it a seeing to with the file) but they
go up to quite a bit bigger.
For the sake of £6ish it's worth getting one from them (postage is about £2 each way)
