Mal
| posted on 10/12/08 at 08:45 PM |
Hydraulic Clutch Pipe Diameter
Like most Midi's mine will have a hydraulically operated clutch. The Focus clutch release on the Ford IB5 gearbox is operated via a 6mm OD steel
tube.
Since I don't have any 6mm diameter tube to run down the tunnel, but plenty of 5mm (3/16" dia. brake, does anyone know from experience if
the smaller size will allow the cluch to operate satisfactorily?
Mal.
Alan B
| posted on 10/12/08 at 09:53 PM |
My clutch is piped with 3/16" seems to be fine. I have a Honda K20A3 in mine. Some would recommend bigger because of the flow requirements, but
I have no plans to change mine.
Alan
Mal
| posted on 10/12/08 at 10:48 PM |
Thank you Alan
