designer
posted on 19/3/09 at 11:29 AM |
Poor man's vacumn bagging.
Intending to do composites
http://www.krsuper2.com/vacuumbag.html
RK
posted on 19/3/09 at 12:08 PM |
Why won't a regular vacuum cleaner work? It draws air out as well as anything if you arrange the hose correctly so it doesn't get stuck in
one spot.
It strikes me that once you buy all this crap to go DIY professionally, you are beyond the purchase price of everything you'd want!
ps says the guy building his own car...
[Edited on 19/3/09 by RK]
dinosaurjuice
posted on 19/3/09 at 12:16 PM |
regular vacumn cleaners require air flow to keep them cool. without this they burn out fairly quickly.
MikeR
posted on 19/3/09 at 12:20 PM |
so put a fan next to the motor.
balidey
posted on 19/3/09 at 12:27 PM |
Or use a venturi vac generator run from a compressor. Costs a couple of quid
EDIT: ok maybe not a couple of quid, but about £10 from RS will get you one.
[Edited on 19/3/09 by balidey]
PAULD
posted on 19/3/09 at 12:34 PM |
vacuum bagging
I believe a motor/pump unit from a fridge is the thing to use.
twybrow
posted on 19/3/09 at 01:33 PM |
Read the article!!! It explains why the fridge pump is no good - the CFM rate is just too low to overcome any leaks you get (which you will have).
A vacuum cleaner can only pull around 600mbar residual, whereas you need something to pull down to ~3mbar. you can pick them up on ebay from £50
upwards....
balidey
posted on 19/3/09 at 02:00 PM |
depends on the size of panel and how good the seal is, but I have used a cheap venturi type vac generator with no probs.
spewing
posted on 19/3/09 at 02:28 PM |
All vacuum pumps work best pulling against something.
What you need is a reasonable size canister in the line to the vacuum pump. This gives the pump a volume to pull against which in turn pulls a vacuum
against the material being vac bagged.
By the time you've evacuated the bag you are just have atmosphere pushing against the resign and material and the pump can only pull against the
pipe.
If the canister you put in the line is large enough you can use a fridge pump to evacuate it over some time and then open an isolator between the
canister and the vac bag to evacuate the air in the bag giving the fridge pump a better opportunity to recover the vacuum.
The same applies to all vacuum pumps and if you have a canister in the line you can get good results with the venturi type vacuum pumps. (the type
that use water rather than compressed air pull a better vacuum but you wouldn't want to use one if you were on a water meter)
Kev
