pocket rocket
posted on 23/10/09 at 07:58 PM |
alternator problems
Hi Guys,
my alternator is stuck solid i put my aux belt on this evening ready to get the engine running tomorrow only to find the engine won't turn
over with the belt on... the reason is the alternator pully is stuck solid... i can't even turn it with a socket and ratchet is there
anything i can do to fix it or do i need a new on?
i was thinking hit it with a hammer??? lol
Dam...iv consused my ability with my intentions!
posted on 23/10/09 at 08:00 PM |
Could be the pulley is jamming against the body of the alternator ? Unlikely but possible
speedyxjs
Do you know why it is stuck? Rust?
pocket rocket
posted on 23/10/09 at 08:12 PM |
no idea its a bit dark in my workshop and the alternator is hard to get at with the engine in place plan is to take it off sunday and have a
good look.
if it is rust can you clean them up so they work ok or should i bin it and get a new one?
speedyxjs
posted on 23/10/09 at 08:14 PM |
If it is rust or something easily fixed, i would sort it, put it back on the car and hopefully it will still work fine. No point buying a new
alternator if you dont need to.
posted on 24/10/09 at 09:14 AM |
stuck alternator?!?!?!
not heard of that one
what model/make is it?
usualy there are two bearings for the sahft so it should turn easier than an easy turny thing.
maybe the bearings have seized? or fitted incorrectly so the shaft cannot run?
also the brashes may have gouged into the cummutator but they are carbon = brittle so would have though they'd have searred off.
ahs it ever turned or this happen recently?
[Edited on 24/10/09 by 02GF74]
pocket rocket
posted on 24/10/09 at 11:57 AM |
well i got up at 7am this morning so i would have time to take it off and have a look at it before i had to leave for work.
once i had it off i used a ratchet strap to strap it down to the work bench and have a good go at it... from what i can make out it looks like some
grp dust had got in and around the pully and bearings, this with a bit of rust had locked it solid.
10 minutes with an air compressor, some wd40, a 24mm socket and ratchet and a rubber mallet and it is now free and, to quote 02GF74 'turns
easier than an easy turny thing'
yet to see if it works as an alternator still but fingers crossed it will be ok.
thanks for the help guys
