MakeEverything
posted on 15/11/09 at 06:04 PM |
2.2 TURBO!! :D
Got the turbo fitted and all working, and took it for a test drive tonight....
OH MY GOD!!!
Pulled out of the drive, and gave it a boot full! - Pulls away almost twice as quick as before the turbo was fitted!
Have got some more work to do to make it a lot safer, (Using drainpipe for boost hose connections currently), but now i know it works, ill get it done
properly!
Kindest Regards,
Richard.
Dangle_kt
| posted on 15/11/09 at 06:06 PM |
excellent!
What engine is it?
Bet it felt like warp factor 10!
londonsean69
| posted on 15/11/09 at 06:07 PM |
Nice one
l0rd
| posted on 15/11/09 at 06:16 PM |
OH MY GOD!!!
properly!
are you saying that drainpipe is not how it is properly done?
[Edited on 15/11/09 by l0rd]
liam.mccaffrey
| posted on 15/11/09 at 06:29 PM |
if thats all you got drainpipe is fine
Build Blog
Build Photo Album
iscmatt
| posted on 15/11/09 at 07:58 PM |
what engine?? also pics and vid are required
MakeEverything
| posted on 15/11/09 at 08:10 PM |
Its a 2.2 Renault 25 engine and transaxle.
Pictures in my photo album without the turbo. Turbo picture to follow!
The drainpipe is above the turbo, so will melt eventually. I need to change it for some aluminium tube and re-route it.
Also need to put the oil feed and return in fully.
The idea behind the trial, was to see if the stock ECU deals with the added boost. - It seems to, so ill leave it in for now.
It did feel like warp factor 10, and the revs werent all that high either! Should be able to get a load more out of it.
Kindest Regards,
Richard.
l0rd
| posted on 15/11/09 at 08:38 PM |
take it easy. It sound a blast but make sure you don't blast the engine
MakeEverything
| posted on 15/11/09 at 09:00 PM |
Knowing what im like, i dragged AndyB out last weekend to help me pick up a 2.0 Turbo engine! Ive got a spare, but id rather stick with the 2.2
tbhg!!
Kindest Regards,
Richard.
l0rd
| posted on 15/11/09 at 09:34 PM |
So from the 110 dead Hp you should now have about 150ish ones?
According to wikipedia you should have about
175HP
Xtreme Kermit
| posted on 15/11/09 at 09:42 PM |
good effort!
madteg
| posted on 15/11/09 at 10:36 PM |
Welcome to TURBO POWER he he he
MakeEverything
| posted on 15/11/09 at 11:43 PM |
175HP
Standard engine had 123hp allegedly, so i reckon your figure isnt too far off. Until i get it all installed properly and tested, ill not know for
sure.
Its good though!
Kindest Regards,
Richard.
MakeEverything
| posted on 15/11/09 at 11:47 PM |
175HP
sure.
Its good though, as the car only weighs in at 900kg!
Kindest Regards,
Richard.
MakeEverything
| posted on 5/12/09 at 02:54 PM |
Sump Modification
Finally did it. I got around to taking off the sump of the spare engine i had. It turns out, that there is a blank casting on the side of the sump,
which i drilled out and inserted a piece of ali tube, and welded with alumiweld.
The sump i modified is ali, and the one its replacing is steel, so its an upgrade as well!!
Going to have a look and see what else i can swap over as performance upgrades once the turbo is complete.
Kindest Regards,
Richard.
MakeEverything
http://locostbuilders.co.uk/upload/IMG00032-20091205-1447.jpg
Kindest Regards,
Richard.
