pdm
posted on 5/1/10 at 08:52 AM |
OT - house wiring
Morning all,
I'm hoping that someone on here will know the answer to this...
My house is 8 years old and has a concrete screed floor.
My question is which way are the wires normally run through the wall for plugs and lights both up and downstairs ?
thanks
Paul
locoluego
posted on 5/1/10 at 09:00 AM |
all houses follow the same rule solid floors wires come down wood floors wires go up all of your wiring will come down the wall probably between the
plaster board and the breeze block with a metal conduit cover or they will be chased in to the block
pdm
posted on 5/1/10 at 09:07 AM |
Nice one - I knew this was the place for the answer to a practical question.
Thanks.
big-vee-twin
posted on 5/1/10 at 09:16 AM |
Same for your water and Radiators
http://www.triangleltd.com
posted on 5/1/10 at 09:28 AM |
Have you had the house from new? If not then it's worth remembering that previous owners/occupiers may have added to or changed the wiring -
people don't always do this properly as I have learnt the hard way (electrocuted ).
Also, a digitial stud/pipe/wire finder is not expensive and can be very useful for checking where things are before drilling holes, cutting plaster
etc.
Finally, house electrics are now covered by Part P rules. I'm not an expert (there are qualified and experienced people on the forum though)
but there are legal rules on what you can and can't add or change without requiring test and certification from a qualified electrician.
Howlor
posted on 5/1/10 at 09:40 AM |
I am sure I have seen cables run diagonally on a new build we looked around.
That could be interesting!
skinned knuckles
posted on 5/1/10 at 10:40 AM |
the rules are to run wires vertically down the walls and through the joist cavity in the floor above. they should be chased in to the walls protected.
before being plastered over.
but unless you are completely certain of where they are you can buy a detecter from any DIY store that will detect where the wires are. they will also
tell you where the water pipes are and some will even show you where the studs are.
most regestered sparks will have installed thing properly but you never know how who has done any bodging since. spend the couple of quid on the
detector, its never nice being zapped and a real pain in the bum when you hit a central heating pipe.
A man isn't complete until he's married, then he's finished
SteveWalker
posted on 5/1/10 at 11:15 AM |
I think that has always been allowed, as long as the cable is physically protected by steel conduit or similar, otherwise it's a strict no-no.
big-vee-twin
posted on 5/1/10 at 11:37 AM |
There are zones for wiring stipulated in the wiring regs which are vertical and horizontal.
But like previous who knows what people do in their own homes
Bluemoon
posted on 5/1/10 at 12:16 PM |
Don't trust it's done as it should be... Check as well..
Dan
pdm
posted on 5/1/10 at 01:05 PM |
Great thanks everyone woh replied - think I'll get one of those detectors !!! Better to be safe than sorry.
posted on 5/1/10 at 05:55 PM |
Aye, if its in its safe zone its ok, if not then it needs to be more than 50mm deep or in earthed armoured conduit. With the 17th it also needs an RCD
if not in the aforementioned conduit.
Very few sparks would run stuff diagonally just because it looks like a bodge.
dhutch
posted on 5/1/10 at 06:05 PM |
Yes, as said, deviation from that is uncommon.
In otherwords, in a bog std house, 90% of the wiring is in the joist space between the ground and first floor. With lighting for the first floor run
in the attic space.
My uncals house also had its ground floor rads plumbing run in the floor screed. This was true for all the street, which all failed at around 30years
(thats 70's building for you) but it is uncommon.
Metal detectors can be useful, but the £5 ones are useless, so if you doing much at all spend a little more. We have a a £30 one and its quite usable
with a bit of practice.
Daniel
