Dangle_kt
posted on 22/4/10 at 04:51 PM |
why exhaust studs?
why not just bolts?
just curious.
blakep82
posted on 22/4/10 at 04:55 PM |
always wondered this myself. was going to change mine to cap head bolts...
________________________
jollygreengiant
posted on 22/4/10 at 04:57 PM |
Have you EVER tried to line up a springy stainless steel multi branch exhaust manifold and THEN put bolts in.
Trust me STUDS rock.
blakep82
posted on 22/4/10 at 05:01 PM |
i left one stud in
Mark Allanson
posted on 22/4/10 at 05:02 PM |
Simple, its to make fitting a manifold so much more difficult to fit when its in a confined place.
boggle
posted on 22/4/10 at 05:04 PM |
i allways thought it was to do with the heat expansion, contraction thing???
u2u me for details
55ant
posted on 22/4/10 at 05:10 PM |
as above lining up and fitting gaskests, saying that i have used bolts for my inlet manifold.
away from cars, now cycling and building TT bikes
Guinness
To make use of all those mountains of stud extractors?
Benzine
posted on 22/4/10 at 05:13 PM |
it's got something to do with clouds
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
Andy W
posted on 22/4/10 at 05:17 PM |
I wouldn't have thought you would want to be removing bolts from your head to often, especially if it's alloy.
Paul (Notts)
posted on 22/4/10 at 05:33 PM |
as above -- alloy heads and bolts
v8kid
posted on 22/4/10 at 05:46 PM |
How often do you take your manifolds off
I've got bolts on mine but will be converting to studs 'cos of allignment probs already noted above but it's one of those jobs well
down on the list
bi22le
posted on 22/4/10 at 06:42 PM |
I always thought it was due to heat. Then again I have never tried to line up a gaskit and manifold!
Please read my ring story:
dhutch
posted on 22/4/10 at 07:43 PM |
This is the main reason for studs of bolts in any application.
You wear out the nuts first (cheap), then the studs (not overly expensive) but never the threads in head (really very expensive) unless your really
ham-fisted with changing the studs if you ever need to.
Daniel
nitram38
posted on 22/4/10 at 08:08 PM |
Another reason if you use bolts that are too long they bottom out before pulling the manifold tight enough to seal.
Studs bottom out and the nuts take up any differences.
