eznfrank
posted on 5/6/10 at 11:29 AM |
Anyone know if ZX12 hi and lo beam operate when engine not running?
As above, I've just wired in the headlights and only the sidelights are playing ball but they run off a circuit which appears to be live without
engine running but I'm trying to check my wiring without starting engine if poss.
Anyone happent to know if hi and lo beam on a ZX12 are only live when engine running (I think so?)
mangogrooveworkshop
posted on 5/6/10 at 11:36 AM |
You may need the ignition to be on position 1
Frank
spiderman01980
posted on 5/6/10 at 01:01 PM |
i`ve just finished my wiring on a gpz900 kawasaki engine, the engine don`t need to be running for all the wiring to work all it does while its running
is keep the battery charged, just check all the fuses, all the earths are correct and the ignition barrel works as mine didn`t send power to the
starter button, so had to cross a wire and it works now!
Andy W
posted on 5/6/10 at 01:39 PM |
zx10r does
eznfrank
posted on 5/6/10 at 02:44 PM |
Cheers, I think I've made a boob with the wiring then, probably just a dodgy earth I guess, it's just not easy to check without taking my
battery tray out. Good news is that my indicators, hazards, side lights, fan overide all work. Just got to get back under the tray now and figure
out why the rest isn't.
posted on 5/6/10 at 03:08 PM |
The dip and main will only operate with the switch in the engine run position on all the bikes I've ridden.
Johneturbo
posted on 5/6/10 at 03:58 PM |
i think it's a thing with newer bike my 09 zx6r needs engine running, as only the side lights come on with just ignition
but my old 01 J2 ninja the main/dip would work with just ignition on
