dave
posted on 9/6/10 at 10:29 PM |
Bugger
Just been informed that you cant refit the sump on a mx5 engine with it connected to the gearbox it has to be separated. Not much good if the engine
and box are fitted in the car.
NigeEss
posted on 9/6/10 at 10:41 PM |
Seems a bit odd but..............
Doh !
[Edited on 9/6/10 by NigeEss]
mad4x4
posted on 10/6/10 at 06:18 AM |
The Zetec Engine is the same . The sump tucks into behind the fly wheel /shit plate so you should really remove the Gear box and remove the fly wheel
to re-fit - PITA.
Scot's do it better in Kilts.
posted on 10/6/10 at 06:33 AM |
Same for the Xflow - although you can just about get away with separating the engine and gearbox by an inch or so.
dhutch
posted on 10/6/10 at 10:34 AM |
the fly wheel to re-fit - PITA.
When you say 'should really' does that correctly imply that the sump can infact be removed without taking the flywheel/gearbox off?
Certainly the cvh goes on and of with easy which has been useful in the past.
Daniel
JimM
posted on 10/6/10 at 11:51 AM |
Looks like your have same luck as i am ... one step forward and two steps back. When do you think you will be back on the road .... Is the Gairloch
blat in doubt?
mad4x4
posted on 10/6/10 at 11:53 AM |
On the zetec the sump catches on the poo plate (what is the technical Name)
and complete **** to remove. Then spent 2 Hours (with oil dripping on me) once I got it out trying to refit. Was sooooo tempeted to just whip out
the engine but couldn't be bothered.
Next time i'll remove the engine..
