Author: Subject: Midi Builders; What diameter coolant pipes are you using?
2cv
posted on 1/7/10 at 01:26 PM Reply With Quote
Following on from my electric pump thread, I'd be interested to know what diameter pipes are being used from engine to radiator.
v8kid
posted on 1/7/10 at 01:30 PM Reply With Quote
32mm id ally for 5.0l v8 no problems
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Alan B
posted on 1/7/10 at 01:36 PM Reply With Quote
I'm using 1.25" Alum. for my main pipes...around 32mm
Water pipes
Water pipes
[Edited on 1/7/10 by Alan B]
posted on 1/7/10 at 01:37 PM Reply With Quote
32mm aerial pole from B&Q
CNHSS1
posted on 1/7/10 at 01:41 PM Reply With Quote
28mm mains water copper tube on my front engined/rear radiatored car, easy to work and can have hard soldered joints and bends easily
2cv
posted on 1/7/10 at 01:53 PM Reply With Quote
Thanks Chaps. I probably should have gone larger but difficult to change at this stage.
CNHSS1 is using 28mm copper the same as I am so a couple of quick questions for you if I may;
1 What engine and rad are you using?
2 Are you using the standard water pump or electric?
3 What is the running temperature?
4 Are you using the standard thermostat or a remote one fitted into the bottom hose?
Thanks for your help.
afj
posted on 1/7/10 at 02:41 PM Reply With Quote
+1 ON THE AERIAL POLE FROM B&Q
caps lock dam it
[Edited on 1/7/10 by afj]
eerrrrrrrrrrrrrrrr
hughpinder
posted on 1/7/10 at 02:49 PM Reply With Quote
To check if the system can transfer enough heat to the radiator using the current pump and pipe, perform this (free) test. Remove the thermostat completely. Run the engine. If the engine still runs too hot, you are not getting enough flow round the coolant loop. If it runs cold you need a better thermostat.
Domestic plumbing systems calc a 28mm pipe should allow 40Kw of heat transfer into rooms at 20DegC from water at 70DegC (if your radiatros are big enough). ETA I thinks thats actually limited by the boiler to pipe transfer though as the temperature differrence there will be least.
Regards
Hugh
[Edited on 1/7/10 by hughpinder]
2cv
posted on 1/7/10 at 03:21 PM Reply With Quote
Thanks Hugh. Do you think the thermostat is impeding the water flow or that it opens at a too high a temperature? I'm currently using an 82 degree thermostat in place of the 89 one that was in originally. The engine still gets up to the same temperature but it just takes longer to get there.
Can you clarify how your para 2 relates to an engine situation.
Thank you.
hughpinder
posted on 1/7/10 at 04:26 PM Reply With Quote
I think the thermostat is restricting flow. Removing it will prove weather this is the case or not. Obviously if the temperature tops out at (say) 70 degrees with no stat in you may be able to get a stat that allows more flow to pass. If not, a higher pressure pump will push more water through the restriction.
What size are the inlets and outlets on the radiator? - theres little point in replaceing the pipes if the pipe diameter is already as big as the radiator inlet.
The second paragraph just gives an indication of how much heat you can pass down a 28mm pipe.
Regards
Hugh
2cv
posted on 1/7/10 at 04:41 PM Reply With Quote
Thank you Hugh, The radiator stubs are for 32mm rubber hose. I'm reducing down to 28mm copper through the car and then back to 32mm rubber hoses to connect onto the engine. At this stage, it would be a major redesign to put in larger diameter pipes and I'd really not want to contemplate that! I'll certainly try running without a thermostat and see if that makes any difference so thank you for that suggestion.
I'm also going to do a comparison running in 4th gear against 5th because higher revs will increase pumping speed. If running in 4th drops the temperature then that will show that it is a question of flow and that an electric pump will be the answer.
hughpinder
posted on 1/7/10 at 05:15 PM Reply With Quote
Sounds like a good plan
Hugh
blakep82
posted on 1/7/10 at 10:11 PM Reply With Quote
er, i'd really go with the diameter of the connections on your engine and radiator. thats where i'd start
mine are 35mm on the engine, 38mm on the radiator, so 35mm pipes, and 38 to 35mm reducers on the radiator
________________________
Alan B
posted on 2/7/10 at 12:08 AM Reply With Quote
Blake....pretty much my thinking...32mm at the engine.....32mm at the rad.......erm.....what about 32mm tubing???... worked for me
2cv
posted on 2/7/10 at 06:50 AM Reply With Quote
blakep82 and Alan B, you are quite right to be scathing and in retrospect I would have done the same. However, the reason I went for 28mm copper was that it fits inside the car under the seats so space is restricted and I can bend it. I have no means of bending larger sections. I had hoped that 28mm tube would have been adequate.
Alan B
posted on 3/7/10 at 11:45 PM Reply With Quote
I can't speak for Blake of course, but there was no scathing intended from me....just a very simplistic approach, which may or not be correct......whatever works...works....simples..
2cv
posted on 4/7/10 at 09:11 AM Reply With Quote
quote: I can't speak for Blake of course, but there was no scathing intended from me....just a very simplistic approach, which may or not be correct......whatever works...works....simples..
Thanks Alan. you only pointed out what I already deep down knew that it wasn't the best decision in the world to reduce the diameter of the makers design particularly in view of the length of the pipes.
However, all is well and the problem was not one of water flow but getting the air out from under the bonnet. Running without the bonnet produced a much lower and very stable running temperature so, quite a relief really.
