misty1
posted on 23/8/10 at 09:20 PM |
how to modigy the sierra pedal box to fit the locost
Hi all
does anyone know how to modify te sierra pedal box to make it fit in the locost
pics or ideas would be really helpful
many thanks
scoop
posted on 23/8/10 at 09:37 PM |
You need to mount them above the top rail and then shorten them to fit your feet.
misty1
posted on 23/8/10 at 09:52 PM |
MANY THANKS FOR COMING BACK SO FAST
DO YOU NOT MEAN LENGTHEN TO SUIT THE FEET?
RichardK
posted on 23/8/10 at 09:57 PM |
I had to lengthen mine on my first attempt but didn't like the driving position so made some floor mounted jobbies.
Rich
BTW mate, writing in caps is like shouting
Gallery updated 11/01/2011
misty1
posted on 23/8/10 at 10:01 PM |
Take your point no shouting too late at night but yes i think i might have to do that way and make floor mounted ones
thanks for the info
austin man
buy or make a set of floor mounted pedals they take up less space
RichardK
posted on 23/8/10 at 10:07 PM |
thanks for the info
Made my floor mounted pedals from large casters but take the wheel out, you are then left with a nice strong u shaped brackets!
Loads of pictures in my gallery, link below...
Rich
Oh btw, welcome to the mad house!!
[Edited on 23/8/10 by RichardK]
misty1
posted on 23/8/10 at 11:07 PM |
those are brill what size castors did you use?
interestedparty
posted on 24/8/10 at 05:30 AM |
Don't know if you have been for IVA yet, but using bolts for the brake pedal and clevis pivots is frowned upon
[Edited on 24/8/10 by interestedparty]
Macbeast
posted on 24/8/10 at 06:43 AM |
What else would you use ? My pedals pivot on collars held to brackets with bolts.
daviep
posted on 24/8/10 at 08:26 AM |
Depends on whether it is a bolt or set screw, if you use a bolt with a plain shank the correct length to go all the way through the bracket there is
no problem.
I wouldn't use a set screw.
Davie
interestedparty
posted on 24/8/10 at 08:55 AM |
I assumed it would be a bolt, never occured to me that someone would use a machine screw. Never the less, I know someone who failed SVA on that.
Tester wanted a securing method such as a split pin rather than a nut.
Maybe varies from one tester to another.
RichardK
posted on 24/8/10 at 09:30 AM |
Did the sva thing back in 2008, they are 12 ton bolts, double nut'd and marked with red paint.
No problems at sva at all but dont know about current regs.
Rich
40inches
posted on 24/8/10 at 03:02 PM |
thanks for the info
Rich
That's a stroke of genius, nice bit of lateral thinking
