Author: Subject: My new toy - everyday - project
MK9R
posted on 6/9/10 at 09:19 AM Reply With Quote
Picking this up on wednesday
http://www.pistonheads.co.uk/sales/1968119.htm
bit more info:-
"Running gear a combination of mini and metro front disc metro, subframes
classic mini with new spax gas shocks, gearbox metro turbo, engine Cooper
MPA with 1 3/4 SU. Rebuilt. Standard inners. 5 1/2 x13 wheels and 185/60/13
tyres. Sony cd /radio with 4 speaker system. Roll hoop with hard top and
soft top. Another engine and gearbox in bits could be available. Good basic
car engine fault is simple no internal issues Builder manual. Some yellowing
of the body due to UV over the years but good at arms length!, and few star
cracks at engine hidges and were the carb is close the under bonnet.
Ran well all through the winter and spring months, then started
to cause problems with tickover.
Fitted an electronic pump as though it was fuel starvation. Drained the fuel
tank. Played around with timing and distributor. Think it is mixture on the
carb nothing major. Got it running perfectly for one day would not go the
next. Just bloody annoying."
Its just a little road toy that i can commute to work in when i fancy it, always liked them and this one popped up at the right money. Plan is to get it running, then tart up internally and externally, with the same martini race colours of the fury so i have matching pair
So where shall i start tracking down the engine problem??
[Edited on 6/9/10 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
iank
posted on 6/9/10 at 09:32 AM Reply With Quote
Nice cars and cheap for what you get.
I'd suspect heat if it worked ok in the winter and started playing up in summer.
Maybe the coil?
p.s. this months complete kit car shows a conversion kit from z-cars fitting a 2 litre honda lump into a rossa. page 13 if you're in WHSmiths
Anonymous
BobM
posted on 6/9/10 at 09:33 AM Reply With Quote
So when do we expect to see this on the RGB grid?
Not very Locost but very BEC
MK9R
posted on 6/9/10 at 09:34 AM Reply With Quote
no no no, no BEC!!!! It fits in the bus though
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 6/9/10 at 09:35 AM Reply With Quote
Maybe the coil?
stop it!!! i'd already thought of that!!!! I had a K20 in my elise and it was pretty damn awesome!!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
TimC
posted on 6/9/10 at 09:40 AM Reply With Quote
I'm not sure your fleet (bus included) consists of enough white GRP.
Are those 205 rear light clusters? Would benefit from some red aftermarket replacements imo.
ETA: Just noticed the steering wheel. That is schweeeeeeeeeet. Ffffnarrrrrrr!
[Edited on 6/9/10 by TimC]
MK9R
posted on 6/9/10 at 09:54 AM Reply With Quote
Metro items Classic mini subframes, plus some metro bits. Very simple! Just a bit of fun on the way to work, my run up to liverpool is going to be a cracking fun
Cheers Austen
RGB car number 9
www.trackace.co.uk
posted on 6/9/10 at 10:13 AM Reply With Quote
Said steering wheel will, I think, require the wearing of beige string back driving gloves and possibly the use of a pipe
MK9R
posted on 6/9/10 at 10:42 AM Reply With Quote
LOL, i'll have to see if i can get a walnut dash kit to make it into a true english sports car
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 6/9/10 at 10:45 AM Reply With Quote
actually yes, looks like pug lights
Cheers Austen
RGB car number 9
www.trackace.co.uk
Danozeman
posted on 6/9/10 at 11:17 AM Reply With Quote
He he i like them. Put a k series in it.
As for the running trouble, coil? Valve clearances? Carb full of crap and wrong oil in the su?
Dan
adithorp
posted on 6/9/10 at 01:02 PM Reply With Quote
Not bad for a kit you can use every day.
I've seen a couple at track days and the handling looked... hmm... interesting!
adrian
http://jpsc.org.uk/forum/
MK9R
posted on 6/9/10 at 01:05 PM Reply With Quote
adrian
i've heard they flex a "little" more without the hard top on . Got my hardened track machine, a bit of road fun and would actually like it to be tail happy
Cheers Austen
RGB car number 9
www.trackace.co.uk
adithorp
posted on 6/9/10 at 02:49 PM Reply With Quote
Catching up with them there seemed to be something odd going on with the rear end and a tendancy to lift the inner rear wheel. They were pretty twitchy coming out of corners and didn't inspire confidence to overtake entering a stright.
adrian
MK9R
posted on 6/9/10 at 02:53 PM Reply With Quote
adrian
yup, they twist a bit ;-) Fitting a full cage sorts it out though ;-)
Cheers Austen
RGB car number 9
www.trackace.co.uk
PAUL FISHER
posted on 6/9/10 at 04:47 PM Reply With Quote
Looks like a great buy, for that sort of money your can't go wrong
MK9R
posted on 6/9/10 at 04:51 PM Reply With Quote
It may appear on ebay in few months time you never know
Cheers Austen
RGB car number 9
www.trackace.co.uk
