Author: Subject: question on fuse box!
chunky2772
posted on 6/10/10 at 08:44 PM Reply With Quote
can i use the fuse box fitted to the bike wireing loom for my kit car or do i need to change this for iva.
MakeEverything
posted on 6/10/10 at 08:48 PM Reply With Quote
Should be ok? Check the IVA Manual for references.
Kindest Regards,
Richard.
chunky2772
posted on 6/10/10 at 09:09 PM Reply With Quote
thanks! but was hopeing someone on here had been throught iva that has used the bikes fuse box on there build so i know for sure!
chunky2772
posted on 6/10/10 at 09:36 PM Reply With Quote
also can anyone tell me where i need to mount the battery cut of switch! can this be under the bonnet or does this have to be mounted on the dash
snapper
posted on 7/10/10 at 05:15 AM Reply With Quote
A fuse box is a fuse box, no specific regs on which one or what type for IVA.
Cut out switch can be mounted any where, on the dash or under the dash can cause radius/contact problems for IVA so under the bonnet is better
I eat to survive
I drink to forget
Breaker
posted on 7/10/10 at 09:14 AM Reply With Quote
Is a cut off switch mandatory for IVA ? What chapter can I find it in in the IVA manual ?
chunky2772
posted on 7/10/10 at 07:01 PM Reply With Quote
thanks for that snapper ill put it under the bonnet out the way.
