Chaddy
posted on 23/10/10 at 11:47 AM |
Air box inlet size
Will a 70mm inlet into my air box be big enough to feed my R1. I am restricted for space and intend to use the remote carbon can air filter from CBS.
Will this set up work ok or will I get air starvation.
[Edited on 23/10/10 by Chaddy]
RazMan
posted on 23/10/10 at 11:49 AM |
My V6 only has a 70mm inlet size - mind you, that doesn't rev quite so high as an R1
Raz
SPYDER
posted on 23/10/10 at 03:02 PM |
According to the Jenvey website your 70mm feed should be ample.
Select "throttle bodies" from the menu on the left then drop to "single throttle body".
It makes an interesting read.
Geoff.
JENVEY LINKY
Chaddy
posted on 23/10/10 at 06:16 PM |
Thanks guys
I'll go with the 70mm
