Author: Subject: Crash damaged kit as donor
richwill
posted on 18/11/10 at 09:51 PM Reply With Quote
If i were to buy a crash damaged kit car ( cat C ) and took all the parts from it and put them on a new chassis would this be legal.Would the crashed car be considered a donor and what implications are there in registering it.
blakep82
posted on 18/11/10 at 09:56 PM Reply With Quote
if the parts you replace are identical, not just as in a 7 chassis, but the same model of chassis from the same manufacturer as the original, then i beleive you won't need to re IVA. if you can't get an exact replacement, then you'll have to re iva i think. there's a lot more to it really, but thats the cut down version
________________________
mark chandler
posted on 18/11/10 at 10:03 PM Reply With Quote
CAT C is damaged repairable so just repair I recon.
A these things are really very simple I would look at stripping down, strapping to a flat table and replace the bent bits, it cannot be horribly bent if a CAT C, this would make it a CAT D
pekwah1
posted on 18/11/10 at 10:04 PM Reply With Quote
surely if you are putting parts on a 'new' chassis then it would need to be re-registered and probably iva'd assuming the chassis it's going on isn't already iva'd?
wylliezx9r
posted on 18/11/10 at 10:10 PM Reply With Quote
Cat D is the least amount of damage for a car to be written off ie panel damage or flood damage etc. Cat c is a write off due to chassis damage but is still repairable I believe a cat b is never allowed back on the road due to the extent of the damage.
George Best
Mark Allanson
posted on 18/11/10 at 10:17 PM Reply With Quote
People get confused over cats
Cat D The value of the repair is less than the value of the vehicle, but when added to the salvage value renders the repair uneconomic
Cat C The value of the repair exceeds the value of the vehicle.(Nothing more nothing less)
Cat B The damage to the vehicle renders it unsafe to be returned to the road - but still has residual value, break only.
Cat A The vehicle has no appreciable residual value - burn out etc
dilley
posted on 18/11/10 at 10:25 PM Reply With Quote
If it was really bad it would be a cat B, break only,.
dilley
posted on 18/11/10 at 10:26 PM Reply With Quote
Too late, should have read it all first!
adithorp
posted on 18/11/10 at 10:52 PM Reply With Quote
No, if you rebuild usind a replacement, identical chassis or body shell you can transfer the chassis number to the new chassis and then it just requires a DVLA identity check.
http://jpsc.org.uk/forum/
ed1801
posted on 19/11/10 at 08:03 AM Reply With Quote
Exactly - my 12 year old fazer motorbike became cat c after some numpty knocked it over outside my house.
The only damage was some scratches to panels, exhaust and pegs - but to replace these parts with new was more than the 700 odd quid bike was worth. So very little damage but still Cat C. I just ride around on a scratched bike
If it was an almost brand new car that was cat C it is completely different - what damage would you have to do to Cat C a 30 grand car - it's got to be pretty wrecked!
[Edited on 19/11/10 by ed1801]
loggyboy
posted on 19/11/10 at 10:46 AM Reply With Quote
It would likely come under the the principles of the points system.
Allocating a vehicle registration mark:
The vehicle must score eight or more points to retain the original registration mark. If less than eight points are scored or a second-hand or modified chassis or altered monocoque bodyshell is used an Individual Vehicle Approval (IVA), enhanced single vehicle approval (ESVA), single vehicle approval (SVA) or motorcycle single vehicle approval (MSVA) certificate will be required to register the vehicle. A 'Q' prefix registration number will be allocated.
So obviously you would need a 'new' chassis, but it could be from any manufactuer.
The following values will be allocated to the major components used:
chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
suspension = 2 points
axles = 2 points
transmission = 2 points
steering assembly = 2 points
engine = 1 point
So you would get your 8 points from retaining the above items and therefore you could keep the reg and no need for IVA etc.
[Edited on 19/11/10 by loggyboy]
interestedparty
posted on 19/11/10 at 12:06 PM Reply With Quote
BEar in mind that if you do retain the original registration, it will STILL be a CAT C vehicle, even after it is repaired and had the VIC check, so that is obviously going to have an effect on its resale value, if that is an issue
TPG
posted on 19/11/10 at 04:44 PM Reply With Quote
That's it in a nut shell.Think of it as reshelling a tintop.VIC check etc,resale value.
..Which was nice..
