Author: Subject: New rear end...:-)
Alan B
posted on 1/7/04 at 01:47 AM Reply With Quote
New rear end...:-)
Is now moulded.......
pics at..
clicky...
sgraber
posted on 1/7/04 at 04:19 AM Reply With Quote
HOT DAMN! ALAN'S THE MAN!
Yes, I am yelling!
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
pbura
posted on 1/7/04 at 04:20 AM Reply With Quote
DAMNED impressive!
So how'd the pulling go? Are you satisfied with the surface finish (which looks plenty good from the pics, btw)?
Looks strangely like something you'd put on a CAR
How IS the roller? Do you have much work left?
Pete
Pete
violentblue
posted on 1/7/04 at 05:00 AM Reply With Quote
how many are you planning to build? seems a waste to have put all that work in for a 1 off.
BTW just helped a friend stick a jspec 3sgte in his MR2, imagine a lump like that to replace your tired 4age
[Edited on 1/7/04 by violentblue]
a few pics of my other projects
Alan B
posted on 1/7/04 at 11:57 AM Reply With Quote
Steve...thanks...
Pete...thanks , it pulled very easily, I'm convinced that plenty of PVA (which you can see being washed off in the pic) helps a lot...finish is good, but it's definitely being painted...I chose white gel because it (and black) are the cheapest colours...even cheaper that clear gel believe it or not...
Violentblue.....I'm planning/hoping to sell a few...yes you are dead right it is a LOT of work....3SGTE....MMMMMMMMMM.....
Fozzie
posted on 1/7/04 at 12:22 PM Reply With Quote
WOW sir alan,
Thats looking just a wee bit different to when I saw it in May
Top job,(didn't think it would be owt else)
fozzie
ned
posted on 1/7/04 at 12:39 PM Reply With Quote
nice job Alan, but I have to say:
'does my bum look big in this?'
Ned.
beware, I've got yellow skin
Alan B
posted on 1/7/04 at 12:54 PM Reply With Quote
Ned.....I hope not.....I think when you see the whole thing it should be OK.....
timf
posted on 1/7/04 at 01:35 PM Reply With Quote
now you've done it alan
we need a piccy now then
Alan B
posted on 1/7/04 at 02:00 PM Reply With Quote
Tim....that's still a few weeks off yet.....but getting there....this should give a clue though.........
timf
posted on 1/7/04 at 02:14 PM Reply With Quote
looking good alan
but theres a big hole in the front where the engine should be
ned
posted on 1/7/04 at 02:22 PM Reply With Quote
Much more in perspective, thanks Alan.
Ned.
sgraber
posted on 1/7/04 at 03:38 PM Reply With Quote
Originally posted by timf
looking good alan
I think that's where the squirrels go... They need a lot of air I am told. That space looks like it will hold about 150 squirrels. Not much torque with squirrels, but high revving.
ned
posted on 1/7/04 at 03:47 PM Reply With Quote
Steve,
where would they store all their nuts, these squirrels?
Ned.
Alan B
posted on 1/7/04 at 03:55 PM Reply With Quote
Duh.....in the twin nut bunkers behind the seats.......
Alan B
posted on 1/7/04 at 04:00 PM Reply With Quote
Pete
Sorry Pete, I missed this bit......
Roller is pretty much complete....needs a bit more welding, then paint, then build-up....nothing much to make though....
robinbastd
posted on 1/7/04 at 09:42 PM Reply With Quote
As usual,fantastic work Alan.
But the question looms.........what's the next project going to be??
Ian
http://smuttygifts.com/
ProjectLMP
posted on 2/7/04 at 03:11 PM Reply With Quote
Looks really nice. Won't be long to go before the ordeal is over and you can just stand back and appreciate all the hard work Do you have any idea how much it weighs?
Home of the Astronomicalcost Mid engined LMP project
Alan B
posted on 2/7/04 at 03:30 PM Reply With Quote
Thanks all.
I'd guess it's about 20 pounds.
Could have been a bit less if I'd used more balsa and less mat and resin, or if it wasn't going to rear hinged and hence reinforced accordingly. Overall I'm pleased with the weight and rigidity.
Rorty
posted on 3/7/04 at 07:42 AM Reply With Quote
Well done Alan. Fantastic work and good planning. I know some top-class 'glassers, but I've never seen a glass body that looked good until painted.
Lamborghini exhibited some of the worst glass bodies I've ever seen (woven fabric texture right across the roof, and clearly visible in places without sufficient gel coat).
Cheers, Rorty.
timf
posted on 6/7/04 at 03:01 PM Reply With Quote
alan
so when will the inaugural pull of the first mercat body be.
weeks or months.
Alan B
posted on 6/7/04 at 03:08 PM Reply With Quote
Tim
Weeks
The last section of the body mold is waxed ready for PVA...should be laying it up this weekend, then if the mold sections all seperate well then I could be doing the body the weekend after....so this month is very likely...
sgraber
posted on 6/7/04 at 04:01 PM Reply With Quote
Alan, I'm very excited to hear that you are coming along so well! That is excellent news!
I am amazed that the rear part you pulled is only 20Lbs (About 10Kg right?). How many layers of glass is that and what weight cloth? Are you using epoxy resin?
Steve Graber
Alan B
posted on 6/7/04 at 04:38 PM Reply With Quote
Hey Steve...
20 pounds is my rough guess..could be more, but didn't seem too heavy......I very rarely use cloth, this was all CSM (chopped strand mat).....I used 2 layers minimum of 1.5 oz mat....muck thicker in places especially around the hinge points....I always use polyester resin.....waaaaaaaaaaay cheaper...
