Andy W
posted on 7/2/11 at 06:26 PM |
What ignition system for BMW 6 cylinder engine
Hi
Looking for a bit of advice.
A mate of a mate is looking at using a 3.0l BMW engine in a kit, junking everything and fitting carbs.
He's looking for information on ignition sytems to run the engine
Any info will be much appreciated
Cheers Andy
franky
posted on 7/2/11 at 06:34 PM |
why would you junk the standard setup for carbs? It'd cost a fortune to get it running right with a custom ecu/set-up/carbs. you can use all
the standard stuff like the ecu and have all the diagnostics working still. Save yourself ££££'s for zero gain.
[Edited on 7/2/11 by franky]
blakep82
posted on 7/2/11 at 06:36 PM |
if fitting carbs, then i'd go for megajolt with edis 6. cheap and simple. only real issue is setting up a suitable trigger wheel and sensor
bracket. suitable manifold might be expensive
if keeping the standard injection, he could go for megasquirt for ignition and fuelling, but its well beyond me
[Edited on 7/2/11 by blakep82]
________________________
