nib1980
posted on 5/3/11 at 06:19 PM |
identify the exhaust....
Hi All,
I got a manifold that fits a treat to my car, but i have no idea what exhaust can its maent to fit.
can any one tell me?
do i need anything special to make it fit? gaskets rings etc?
Is it a ZX9R can fittment?
many thanks
Neil
[img]
Untitled by nb_photos, on
Flickr[/img]
austin man
posted on 5/3/11 at 06:36 PM |
cant yo remove the flange and get another box to fit ? off topic slightly where did you get the roll cage from?
Andy W
posted on 5/3/11 at 06:40 PM |
Hi
Could well be a zx9 exhaust they mount with 3 studs, I have an alloy can for a zx9 in my garage, I'll measure the holes centres in the morning
for you
nib1980
posted on 5/3/11 at 06:48 PM |
quote: Originally posted by Andy W
Hi
for you
thanks Andy.
Is it for sale aswell?
nib1980
posted on 5/3/11 at 06:49 PM |
Stuart Taylor, now aries motorsport i believe
mark chandler
posted on 5/3/11 at 06:53 PM |
zx9 for me as well, although the pipe should not stick in the can like that, I would expect it top be cut flush after the flange.
Gut the can and extend the internals with perforated tube then the extra pipe makes a bit more sense.
Regards Mark
prawnabie
posted on 5/3/11 at 07:15 PM |
The ZX.. exhausts do extend behind the flange into the exhaust can, but you usually have to cut them down to fit an aftermarket can. GSXR's also
have a similar set up although the are differences between the pcd on the flange between pretty much all of the engine sizes on both makes.
nib1980
posted on 5/3/11 at 07:18 PM |
anyonw know a site that will have the flange dimension for me to look up?
Andy W
posted on 6/3/11 at 04:51 PM |
Hi
Just checked and the holes 45mm PCD
I have an alloy can if you are after one
nib1980
posted on 6/3/11 at 05:01 PM |
Hi
thanks andy, i'll have a measure and let you know ASAP
nib1980
posted on 6/3/11 at 05:16 PM |
Hi
45mm PCD seems very small, is that the radius?
welderman
posted on 6/3/11 at 05:45 PM |
Standard ally fireblade can has 3 holes too. Could fit that
Thank's, Joe
I don't stalk people
nib1980
posted on 6/3/11 at 05:48 PM |
do you know the PCD of them?
welderman
posted on 6/3/11 at 08:55 PM |
I might have one I can check tomorrow
Thank's, Joe
nib1980
posted on 6/3/11 at 09:10 PM |
if you could that'd be great thanks
