Author: Subject: Puma Tacho - J15
theprisioner
posted on 12/2/12 at 05:21 PM Reply With Quote
Puma Tacho - J15
I would ideally like to use the Rally Design RMD gauges in my Sylva J15. I have a Tacho output on the EMU/ECU pin (48) that runs to the instrument cluster and directly to the above unit. Can anybody tell me if the specs of the Ford EMU and a after market Tacho are compatible.
I phoned Rally Design but the chap could only quote the settings on the rear like 4/6/8 cylinders. A calibration pot. An indication that it wires on to the primary of the coil if you have one. What happens with Ford wasted spark! No reply!
I could take a simple pulse generator and work out a bit more of the picture like the number of pulses and their amplitude per 1000/revs but that would only be useful if I had the same information about the RMD gauge.
Any ideas?
will121
posted on 12/2/12 at 05:56 PM Reply With Quote
I can't answer your specific question, but I use a standard fiesta rev counter with my emerald ecu on problem and have now swapped it to am after market lcd rev counter with the same ecu feed with no problems
big_wasa
posted on 12/2/12 at 06:46 PM Reply With Quote
I use an after market gauge with my eec-v I just cant remember what I set it to.
monkeyarms
posted on 13/2/12 at 11:12 AM Reply With Quote
I have ETB gauges - the rev counter is connected to one of the coil pack wires, easy.
