theprisioner
| posted on 30/3/12 at 09:30 AM |
Help needed 1.7 puma (Sigma) fit in Sylva J15
I am trying to fit a 1997 Puma 1.7 (Sigma) engine in my Sylva J15 chassis. I came across this bit preventing the insetion into the chassis at the near
side bottom rail (the bit with the joggle downward).
I have looked up the Ford TIS manual but cannot find this part referenced, I am sure it is there just a bit of a needle in a haystack at the
moment.
Questions:
1) What is it for?
2) Any consequences in removing it temporily?
3) Anyone else found this problem?
melly-g
| posted on 30/3/12 at 09:52 AM |
Camchain tensioner?
Norfolkluegojnr
| posted on 30/3/12 at 10:48 AM |
A pic of where it was on the engine may help
Looks like some for of sensor to me. Is there any electrical plug on the end?
theprisioner
| posted on 30/3/12 at 11:14 AM |
Gearbox thinggy
Sorry, your right no context!
adithorp
| posted on 30/3/12 at 11:21 AM |
(I think) it's a detent spring/plunger on a selector shaft (5th gear?). No problem removing it to fit the box as long as you remember to put it
back.
http://jpsc.org.uk/forum/
melly-g
| posted on 30/3/12 at 12:10 PM |
oop's I didn't realise it was on the gearbox! I feel a bit stupid now for saying camchain tensioner.
Madinventions
| posted on 30/3/12 at 01:08 PM |
Agree with above, it's a detent plunger. Put it back in once the engine is fitted and you should be ok.
Ed.
View my band website:
http://www.shadowlight.org.uk
Norfolkluegojnr
| posted on 30/3/12 at 01:24 PM |
thread hijack - whats a detent plunger? new one to me!
adithorp
| posted on 30/3/12 at 03:44 PM |
In this case...
The selector shafts have a grove in them, that when moved to select a gear, the spring loaded detent drops into and retains the shaft in that
position. Just strong enough to retain the shaft in position but weak enough to be overcome when changing gear. It's what gives the gearchange
it's nice, positive feel.
Detents (of different designs) are also be used to prevent 2 gears being selected at once and on gear lever assemblies to prevent accidental reverse
selection.
Norfolkluegojnr
| posted on 30/3/12 at 04:04 PM |
quote: Originally posted by adithorp
In this case...
selection.
Every day is a school day.
Thanks!
theprisioner
| posted on 30/3/12 at 04:38 PM |
Thanks for all your help chaps, it is a case of added confidence to move on.
theprisioner
| posted on 1/4/12 at 09:44 AM |
More diagrams
For those still curious and to complete the thread:
Item 6 is I guess what we are discussing!
