aerodynamix
posted on 8/4/12 at 06:31 PM |
Pinto Power Will split
TESTING THE WATER OPEN TO SENSIBLE OFFERS , I HAVE BEEN OFFERED A REPLACEMENT FOR PINTO IN MY WESTFIELD BUT HAVE TO SELL THIS TO BUY IT .
WILL SPLIT U2U ME OR CALL ME WITH WHAT YOU WANT
PINTO engine package, came with westfield narrow car I have bought a couple of months ago it was fitted and running and never saw the road .
I am awaiting full confirmation of engine spec so without stripping it cannot confirm exact spec , however my friend is well into mk1 and mk2 escorts
and has seen engine running in the car and has commented it sounds exceptionally good , I have been told that the car the engine came out of was a
rally car (was dry sumped at some point as brackets are still on engine), was built for car , on first stage car was written off , engine was saved ,
car wasn't then got fitted to Westfield .
This can be a complete package if required , it has Dellorto twin 45's on a short straight inlet manifold , has westfield stainless exhaust
manifold ( I may keep silencer I may sell depending on offers) , has shortened steel sump (not the best job but seems to work) , cam belt does not
have cover and cam is seen to have vernier pully fitted . Can come with water pipework and radiator (escort type) if required .
pictures can be emailed on request send me your email adress, engine is still in car running if you want to hear it / see it before let me know , I
can be available at most times to suit . I am in Gloucestershire you can ring me on 07971 264550 (Julian)
[Edited on 9/4/12 by aerodynamix]
aerodynamix
posted on 9/4/12 at 03:02 PM |
WILL NOW SPLIT
WILL SPLIT U2U ME WITH WHAT YOU WANT
PINTO ENGINE
DELLORTO CARBS AND MANIFOLD
EXHAUST MANIFOLD 4 INTO 1 STAINLESS WESTFIELD TYPE
ESCORT RADIATOR
STARTER MOTOR
ALTERNATOR
DISTRIBUTOR
4 SPEED GEARBOX ALSO NOW AVAILABLE
withersdelivers
posted on 12/4/12 at 06:27 AM |
pinto
hi how much for everything except the gearbox ? And is the engine a 205 block pinto? Thanks . Neil.
aerodynamix
posted on 14/4/12 at 09:43 PM |
Sold
Now Sold thanks
